Home » Archived » XML Schema Definition (XSD) » Problem Including schemas
Problem Including schemas [message #38076] |
Mon, 08 March 2004 07:34  |
Ed,
A question that I had over a year ago has come up again and I rummaged
through my correspondence with the Eclipse XSD newsgroups/forums and found
the email below. It's a question concerning nested schemae. I have
included the email at the bottom of this mail.
I took a look at the XML Schema spec and I think that the relevant part is
at http://www.w3.org/TR/xmlschema-1/#compound-schema. I took a look at the
"Professional XML Schemas" published by Wrox, and on page 274 in Chapter
8, there is a bolded out sentence that says "If the schema we include
borrows from other schemas, we only have to reference the topmost schema
for it to pull in other schemas it references".
Hayden Marchant
From 26 Jan 2003:
Hayden,
Sorry for the long delay answering forum questions...
In the example below, B.xsd must have an include of C.xsd in order to be
valid. Including B.xsd in A.xsd will not help to resolve the ref to "id"
in
B.xsd. According to the spec (in my reading of it), for a QName to resolve,
there must be an explicit import/include/redefine directly in the .xsd
file;
the "id" element simply isn't visible in B.xsd when the schema for B.xsd is
being (transitively) processed. Perhaps other processors are more tolerant
of
this error, perhaps even resolving the identifier via indirect
includes/imports, but XSD is strict in this regard. And since the ref to
"id"
doesn't resolve, a placeholder element is provided by XSD instead and that
placeholder doesn't have a type.
Adding the include to B.xsd is not a hack, it's required.
Hayden Marchant wrote:
> I have encountered a problem with the references schema resolving - below
> I explain the scenario:
> I have 3 xsds - A.xsd, B.xsd, and C.xsd.
> Here are snippets of my schemas:
> A.xsd:
> <xs:include schemaLocation="B.xsd"/>
> <xs:include schemaLocation="C.xsd"/>
> <xs:element name="car">
> <xs:complexType>
> <xs:sequence>
> <xs:element ref="service"/>
> <xs:element ref="model"/>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> B.xsd
> <xs:element name="service>
> <complexTYpe>
> <sequence>
> <element ref="id"/>
> </sequence>
> </complexType>
> </xs:element>
> C.xsd
> <xs:element name="id>....
> <xs:element name="model...
> Now, when validating A.xsd, then the whole group of schemas is valid, even
> though the element reference 'id' that is referenced in B, is defined in
> C, and there in no include/import of C. this works since in A.xsd we are
> including both B and C, so as a whole, we have no problems.
> However, when I parse A.xsd with eclipse xsd, and I look at the
> XSDElementDeclaration for 'id' in schema B, when I call
> XSDElementDeclaration.getTypeDefinition() it returns null, and not the
> XSDTypeDefintion for id (whether it be a complex type of simple type).
> At the moment I have hacked my B.xsd to have the include statement.
> Other parsers can cope with this problem, and XML Spy lets my open my
> A.xsd is does not complain (but does complain when I open B.xsd)
> I hope that my explanation is clear.
Ed Merks
Re: Problem Including schemas [message #38109 is a reply to message #38076] |
Mon, 08 March 2004 08:13   |
Hayden,
Clause 4 of http://www.w3.org/TR/xmlschema-1/#src-resolve seems pretty clear
that for a QName to resolve within a schema document, the document containing it
must have an import of that QName's namespace. I don't have access to the book
you mention, but the line you quote only seems to be saying something about how
the schema is assembled and what names are available in that schema for
validating XML instances as described in
http://www.w3.org/TR/xmlschema-1/#cvc-resolve-instance. Just because a name is
available for validating an instance, doesn't mean it's visible in a particular
schema document without an import.
> Ed,
> Hayden Marchant
> From 26 Jan 2003:
> Hayden,
> in
> file;
> of
> "id"
> > A.xsd:
> > <xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:element>
> > B.xsd
> > <complexTYpe>
> > <sequence>
> > <element ref="id"/>
> > </sequence>
> > </complexType>
> > </xs:element>
> > C.xsd
> Ed Merks
Re: Problem Including schemas [message #38142 is a reply to message #38076] |
Mon, 08 March 2004 08:50   |
Just another note. I looked at the xml-schemadev mailing list and found a
connected thread:
http://lists.w3.org/Archives/Public/xmlschema-dev/2002Oct/00 23.html. Seems
like it says that A includes B includes C, means A includes B and C.
> Ed,
> Hayden Marchant
> From 26 Jan 2003:
> Hayden,
> in
> file;
> of
> "id"
> > A.xsd:
> > <xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:element>
> > B.xsd
> > <complexTYpe>
> > <sequence>
> > <element ref="id"/>
> > </sequence>
> > </complexType>
> > </xs:element>
> > C.xsd
> Ed Merks
Re: Problem Including schemas [message #38208 is a reply to message #38109] |
Mon, 08 March 2004 10:42   |
Ed,
Clause 4 is referring to elements of different namespaces - i.e. it's
talking about <import> and not <include>. It seems that there is some
difference in the spec.
Am I right?
Ed Merks wrote:
> Hayden,
containing it
book
how
is
particular
> > Ed,
> > Thanks,
> > Hayden Marchant
> > From 26 Jan 2003:
> > Hayden,
> > in
> > file;
> > of
> > "id"
> > > A.xsd:
> > > <xs:complexType>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:element>
> > > B.xsd
> > > <complexTYpe>
> > > <sequence>
> > > <element ref="id"/>
> > > </sequence>
> > > </complexType>
> > > </xs:element>
> > > C.xsd
even
> > Ed Merks
Re: Problem Including schemas [message #38305 is a reply to message #38208] |
Mon, 08 March 2004 11:27   |
Hayden,
I'm not sure where you are going with this? Given a document with a QName in it,
that QName either uses then namespace of the document or some other one; in the
former case, the document must define something with than name or must include
(directly or recursively) something with that name, in the later case, it must have
an import of that namespace. The document b.xsd doesn't define nor include
something that defines "id", so it is invalid (and it won't suddenly become valid
by virtue of being included in a context that defines "id").
> Ed,
> Am I right?
> Ed Merks wrote:
> > Hayden,
> containing it
> book
> how
> is
> particular
> > > Ed,
> > > Thanks,
> > > Hayden Marchant
> > > From 26 Jan 2003:
> > > Hayden,
> > > in
> > > file;
> > > of
> > > "id"
> > > > A.xsd:
> > > > <xs:complexType>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:element>
> > > > B.xsd
> > > > <complexTYpe>
> > > > <sequence>
> > > > <element ref="id"/>
> > > > </sequence>
> > > > </complexType>
> > > > </xs:element>
> > > > C.xsd
> even
> > > Ed Merks
Re: Problem Including schemas [message #38506 is a reply to message #38305] |
Tue, 09 March 2004 11:28  |
Sorry, my mistake. I was getting 2 different scenarios mixed up. we really
need to get XSD authors to use Eclipse instead of XML Spy - there are too
many illegal XSD's out there :)
Hayden
Ed Merks wrote:
> Hayden,
in it,
the
include
must have
valid
> > Ed,
> > Am I right?
> > Ed Merks wrote:
> > > Hayden,
clear
> > containing it
the
> > book
about
> > how
name
> > is
> > particular
> > > > Ed,
found
part is
the
Chapter
schema
> > > > Thanks,
> > > > Hayden Marchant
> > > > From 26 Jan 2003:
> > > > Hayden,
be
"id"
> > > > in
resolve,
> > > > file;
B.xsd is
tolerant
> > > > of
to
> > > > "id"
that
below
> > > > > A.xsd:
> > > > > <xs:complexType>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:element>
> > > > > B.xsd
> > > > > <complexTYpe>
> > > > > <sequence>
> > > > > <element ref="id"/>
> > > > > </sequence>
> > > > > </complexType>
> > > > > </xs:element>
> > > > > C.xsd
> > even
defined in
are
the
type).
> > > > Ed Merks
Re: Problem Including schemas [message #583867 is a reply to message #38076] |
Hayden,
http://www.w3.org/TR/xmlschema-1/#cvc-resolve-instance Just because a name is
> Ed,
> at http://www.w3.org/TR/xmlschema-1/#compound-schema I took a look at the
> Hayden Marchant
> From 26 Jan 2003:
> Hayden,
> in
> file;
> of
> "id"
> > A.xsd:
> > <xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:element>
> > B.xsd
> > <complexTYpe>
> > <sequence>
> > <element ref="id"/>
> > </sequence>
> > </complexType>
> > </xs:element>
> > C.xsd
> Ed Merks
Re: Problem Including schemas [message #583878 is a reply to message #38076] |
connected thread:
http://lists.w3.org/Archives/Public/xmlschema-dev/2002Oct/00 23.html Seems
> Ed,
> Hayden Marchant
> From 26 Jan 2003:
> Hayden,
> in
> file;
> of
> "id"
> > A.xsd:
> > <xs:complexType>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:element>
> > B.xsd
> > <complexTYpe>
> > <sequence>
> > <element ref="id"/>
> > </sequence>
> > </complexType>
> > </xs:element>
> > C.xsd
> Ed Merks
Re: Problem Including schemas [message #583904 is a reply to message #38109] |
Ed,
Am I right?
Ed Merks wrote:
> Hayden,
containing it
book
how
is
particular
> > Ed,
> > Thanks,
> > Hayden Marchant
> > From 26 Jan 2003:
> > Hayden,
> > in
> > file;
> > of
> > "id"
> > > A.xsd:
> > > <xs:complexType>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:element>
> > > B.xsd
> > > <complexTYpe>
> > > <sequence>
> > > <element ref="id"/>
> > > </sequence>
> > > </complexType>
> > > </xs:element>
> > > C.xsd
even
> > Ed Merks
Re: Problem Including schemas [message #583958 is a reply to message #38208] |
Hayden,
> Ed,
> Am I right?
> Ed Merks wrote:
> > Hayden,
> containing it
> book
> how
> is
> particular
> > > Ed,
> > > Thanks,
> > > Hayden Marchant
> > > From 26 Jan 2003:
> > > Hayden,
> > > in
> > > file;
> > > of
> > > "id"
> > > > A.xsd:
> > > > <xs:complexType>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:element>
> > > > B.xsd
> > > > <complexTYpe>
> > > > <sequence>
> > > > <element ref="id"/>
> > > > </sequence>
> > > > </complexType>
> > > > </xs:element>
> > > > C.xsd
> even
> > > Ed Merks
Re: Problem Including schemas [message #584043 is a reply to message #38305] |
Hayden
Ed Merks wrote:
> Hayden,
in it,
the
include
must have
valid
> > Ed,
> > Am I right?
> > Ed Merks wrote:
> > > Hayden,
clear
> > containing it
the
> > book
about
> > how
name
> > is
> > particular
> > > > Ed,
found
part is
the
Chapter
schema
> > > > Thanks,
> > > > Hayden Marchant
> > > > From 26 Jan 2003:
> > > > Hayden,
be
"id"
> > > > in
resolve,
> > > > file;
B.xsd is
tolerant
> > > > of
to
> > > > "id"
that
below
> > > > > A.xsd:
> > > > > <xs:complexType>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:element>
> > > > > B.xsd
> > > > > <complexTYpe>
> > > > > <sequence>
> > > > > <element ref="id"/>
> > > > > </sequence>
> > > > > </complexType>
> > > > > </xs:element>
> > > > > C.xsd
> > even
defined in
are
the
type).
> > > > Ed Merks
Current Time: Wed Jul 16 21:10:24 EDT 2025
Powered by FUDForum. Page generated in 0.05219 seconds
