Home » Archived » Visual Editor (VE) » java.lang.NoClassDefFoundError: javax/resource/ResourceException
java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #37986] Thu, 20 May 2004 00:44 Go to next message
Originally posted by: shorty7uk.yahoo.co.uk
I am using VE to create a simple WebSphere MQ application.
When I run the program as a Java Application within VE, I am getting this
error:
It appears to be on this statement within the code.
qm = new MQQueueManager(tabProducer.getQueueMgr());
If I run the application outside of VE from a command prompt - the
application works fine.
I assume this is a simple classpath problem within VE but so far I haven't
been able to resolve this and would appreciate any pointers as to what I
may have missed within VE.
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #38081 is a reply to message #37986] Thu, 20 May 2004 08:46 Go to previous messageGo to next message
Is your Eclipse Java project set up to use the same JRE as you're
invoking from the command prompt? Do you have the necessary J2EE
libraries included in your Java project, the library that contains the
javax.resource package?
Note: Run As->Java Application is the exact same launcher as used by a
normal JDT Java file. There's nothing specific to VE if you're having
problems with the Java Application launcher.
- Jeff
> error:
> Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #38114 is a reply to message #38081] Thu, 20 May 2004 09:38 Go to previous messageGo to next message
Originally posted by: shorty7.yahoo.co.uk
Jeff,
I only have the one JRE installed.
This is not a J2EE app - so no, I don't have this library (at least not
knowingly), it is a simple java app invoking WebSphere MQ using the MQ
base classes. I import com.ibm.mq.*
David
> - Jeff
> > error:
> > Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #38147 is a reply to message #38114] Thu, 20 May 2004 10:01 Go to previous messageGo to next message
David,
The problem is the WebSphere MQ classes are referencing code in the
javax.resources package which isn't included in the base J2SE JRE as far
as I know. (It shows up in
http://java.sun.com/j2ee/sdk_1.3/techdocs/api/ not
http://java.sun.com/j2se/1.4.2/docs/api/ ) So even though you're trying
to write a simple J2SE app, you're referencing code that requires J2EE.
It's puzzling that it works correctly from the command line if the J2EE
stuff isn't in the classpath.
- Jeff
David wrote:
> Jeff,
> David
>> - Jeff
>>>error:
>>>Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #38244 is a reply to message #38147] Thu, 20 May 2004 11:17 Go to previous message
Jeff,
I found the problem. I had to include in the Eclipse build path
connector.jar from the MQ java lib. that is where javax/resource resides.
Jeff Myers wrote:
> David,
> - Jeff
> David wrote:
> > Jeff,
> > David
> >> - Jeff
> >>>error:
> >>>Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588910 is a reply to message #37986] Thu, 20 May 2004 08:46 Go to previous message
- Jeff
> error:
> Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588928 is a reply to message #38081] Thu, 20 May 2004 09:38 Go to previous message
Jeff,
David
> - Jeff
> > error:
> > Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588938 is a reply to message #38114] Thu, 20 May 2004 10:01 Go to previous message
David,
- Jeff
David wrote:
> Jeff,
> David
>> - Jeff
>>>error:
>>>Thanks
Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588986 is a reply to message #38147] Thu, 20 May 2004 11:17 Go to previous message
Jeff,
Jeff Myers wrote:
> David,
> - Jeff
> David wrote:
> > Jeff,
> > David
> >> - Jeff
> >>>error:
> >>>Thanks
Previous Topic:Running Frame
Next Topic:Which VE version can be used with Eclipse 2.x and 3.x?
Current Time: Thu Nov 06 10:51:52 EST 2025
Powered by FUDForum. Page generated in 0.05446 seconds
