Home » Modeling » M2T (model-to-text transformation) » Getting a variable which name is the content of another.
Getting a variable which name is the content of another. [message #37912] |
Wed, 12 December 2007 14:07  |
<html>
<head>
</head>
Hi everybody.<br>
I'm a little stuck trying to do something I new how, but suddenly
completely forgot about it.<br>
Let see if I can explain myself.<br>
<br>
I launch my Jet transformation from java code, and while launching it,
I provide a Map with several variables.<br>
Among them, I set:<br>
<br>
<table border="1" cellpadding="2" cellspacing="2" height="60"
width="1032">
<tbody>
<tr>
<td valign="top">packageName<br>
</td>
<td valign="top">schemaLocation<br>
</td>
</tr>
<tr>
<td valign="top">schemaLocation</td>
<td valign="top">nameSpaceURI<br>
</td>
</tr>
</tbody>
</table>
<br>
Then, from within my template, I have the package name, and need to get
the other two values.<br>
I unsuccessfully tried: <c:setVariable select="{$paquetes/@name}"
var="schemaLocation"/> <br>
<c:setVariable
select="{$schemaLocation}" var="nameSpaceURI"/> <br>
<br>
I also tried:<br>
<c:setVariable select="string($paquetes/@name)" var="nombre"/><br>
<% if(context.hasVariable("nombre"))<br>
{ <br>
String nombreActual =
(String)context.getVariable("nombre"); <br>
String slActual =
(String)context.getVariable(nombreActual); &nbs p; <br>
context.setVariable("slActual", slActual);<br>
String nsActual =
(String)context.getVariable(slActual); &a mp;nbsp; <br>
context.setVariable("nsActual", nsActual);
<br>
System.out.println("nombreActual: " +
nombreActual); <br>
System.out.println("slActual: " + slActual);<br>
System.out.println("nsActual: " + nsActual);<br>
}<br>
%> <br>
<br>
For this last code I get some sort of cast exception, I believe, when
trying to access the variables set in the map as "String" elements.<br>
Any hints?, I'm so frustrated because I KNOW I did this before.<br>
<br>
Thanks in advance,<br>
Juan Pedro<br>
</body>
</html>
Re: Getting a variable which name is the content of another. [message #37945 is a reply to message #37912] |
Thu, 13 December 2007 06:13   |
<html>
<head>
<title></title>
</head>
Just to clarify, the map is:<br>
<br>
<table border="1" cellpadding="2" cellspacing="2" height="88"
width="1046">
<tbody>
<tr>
<td align="center" valign="top"><b>KEY<br>
</b></td>
<td align="center" valign="top"><b>VALUE<br>
</b></td>
</tr>
<tr>
</td>
</td>
</tr>
<tr>
</td>
</tr>
</tbody>
</table>
<br>
Thanks,<br>
Juan Pedro<br>
<br>
Juan Pedro Silva escribió:
<blockquote cite="mid:fjpbhh$9ps$1@build.eclipse.org" type="cite">Hi
everybody.<br>
<br>
<br>
width="1032">
<tbody>
<tr>
</td>
</td>
</tr>
<tr>
</td>
</tr>
</tbody>
</table>
<br>
<c:setVariable
<br>
I also tried:<br>
{ <br>
String slActual =
String nsActual =
<br>
nombreActual); <br>
}<br>
%> <br>
<br>
<br>
Juan Pedro<br>
</blockquote>
</body>
</html>
Re: Getting a variable which name is the content of another. [message #37979 is a reply to message #37912] |
Thu, 13 December 2007 09:10   |
------=_NextPart_000_000E_01C83D67.F673F720
Content-Type: text/plain;
charset="iso-8859-1"
Jaun Pedro:
From you messages, I'm guessing that one JET variable contains the name =
of the other, and you are trying to resolve the indirect reference.
So, given that you know $packageName contains a variable name (in this =
instance 'schemaLocation'), how do you get the value of that variable?
The trick it to use 'dynamic' XPath expressions (XPath expresssions =
enclosed in { } ) in a select attribute. At runtime, dynamic expressions =
are resolved into string values prior to being passed to the tag =
handler. (Normally, XPath expressions in select and test attributes =
should not be surrounded by { and } ). Remember that a select attribute =
must contain a valid XPath expression AFTER any dynamic expressions have =
been resolved.
So, in your case, you want the XPath expression: $schemaLocation
But, the variable name 'schemaLocation' is the value of another =
variable, $packageName. So write: ${$packageName}
Example:
<c:get select=3D"${$packageName}"/>
will result in 'namespaceURI'
Note that the expansion of dynamic XPath expression is not recursive, so =
that trying to do another level in indirection in a single select =
attribute will not work. So:
c:get select=3D"${${$packageName}}"/>
would NOT return the value of the variable $nameSpaceURI. Instead, it =
will likely result in a XPath expression compilation error.
Hope this helps,
Paul
"Juan Pedro Silva" <jpsilvagallino@gmail.com> wrote in message =
news:fjpbhh$9ps$1@build.eclipse.org...
Hi everybody.
I'm a little stuck trying to do something I new how, but suddenly =
I launch my Jet transformation from java code, and while launching it, =
Among them, I set:
packageName
schemaLocation
=20
schemaLocation nameSpaceURI
=20
Then, from within my template, I have the package name, and need to =
get the other two values.
I unsuccessfully tried: <c:setVariable select=3D"{$paquetes/@name}" =
var=3D"schemaLocation"/>=20
<c:setVariable =
select=3D"{$schemaLocation}" var=3D"nameSpaceURI"/>=20
I also tried:
<c:setVariable select=3D"string($paquetes/@name)" var=3D"nombre"/>
{ =20
String nombreActual =3D =
(String)context.getVariable("nombre"); =20
String slActual =3D =
(String)context.getVariable(nombreActual); =20
String nsActual =3D =
(String)context.getVariable(slActual); =20
context.setVariable("nsActual", nsActual); =
=20
System.out.println("nombreActual: " + =
nombreActual); =20
%> =20
For this last code I get some sort of cast exception, I believe, when =
Thanks in advance,
Juan Pedro
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Jaun Pedro:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>From you messages, I'm guessing that =
one JET=20
variable contains the name of the other, and you are trying to resolve =
the=20
indirect reference.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So, given that you know $packageName =
contains a=20
variable name (in this instance 'schemaLocation'), how do you get the =
value of=20
that variable?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The trick it to use 'dynamic' XPath =
expressions=20
(XPath expresssions enclosed in { } ) in a select attribute. At runtime, =
dynamic=20
expressions are resolved into string values prior to being passed to the =
tag=20
should not=20
be surrounded by { and } ). Remember that a select attribute must =
contain a=20
valid XPath expression AFTER any dynamic expressions have been=20
resolved.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So, in your case, you want the =
XPath=20
expression: $schemaLocation</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>But, the variable name 'schemaLocation' =
is the=20
value of another variable, $packageName. So write:=20
${$packageName}</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Example:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><c:get=20
select=3D"${$packageName}"/></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>will result in =
'namespaceURI'</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Note that the expansion of dynamic =
XPath expression=20
is not recursive, so that trying to do another level in indirection in a =
single=20
select attribute will not work. So:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>c:get =
select=3D"${${$packageName}}"/></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>would NOT return the value of the =
variable=20
$nameSpaceURI. Instead, it will likely result in a XPath expression =
compilation=20
error.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Hope this helps,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Juan Pedro Silva" <<A=20
href=3D"mailto:jpsilvagallino@gmail.com">jpsilvagallino@gmail.com</A>>=
wrote=20
in message <A=20
href=3D"news:fjpbhh$9ps$1@build.eclipse.org">news:fjpbhh$9ps$1@build.ecli=
pse.org</A>...</DIV>Hi=20
everybody.<BR>I'm a little stuck trying to do something I new how, but =
suddenly completely forgot about it.<BR>Let see if I can explain=20
myself.<BR><BR>I launch my Jet transformation from java code, and =
while=20
launching it, I provide a Map with several variables.<BR>Among them, I =
set:<BR><BR>
<TABLE height=3D60 cellSpacing=3D2 cellPadding=3D2 width=3D1032 =
border=3D1>
<TBODY>
<TR>
<TD vAlign=3Dtop>packageName<BR></TD>
<TD vAlign=3Dtop>schemaLocation<BR></TD></TR>
<TR>
<TD vAlign=3Dtop>schemaLocation</TD>
<TD =
vAlign=3Dtop>nameSpaceURI<BR></TD></TR></TBODY></TABLE ><BR>Then, from =
within=20
my template, I have the package name, and need to get the other two=20
values.<BR>I unsuccessfully tried: <c:setVariable=20
select=3D"{$paquetes/@name}" var=3D"schemaLocation"/> =
<BR> =20
=20
=20
<c:setVariable select=3D"{$schemaLocation}" =
var=3D"nameSpaceURI"/> <BR><BR>I=20
also tried:<BR><c:setVariable select=3D"string($paquetes/@name)"=20
var=3D"nombre"/><BR><%=20
if(context.hasVariable("nombre"))<BR> =
=20
=20
<BR> =20
String =
nombreActual =3D=20
=20
=20
<BR> =20
String =
slActual =3D=20
(String)context.getVariable(nombreActual); &nbs p; =20
=20
<BR> =20
=20
context.setVariable("slActual", slActual);<BR> =20
=20
(String)context.getVariable(slActual); &a mp;nbsp;=20
<BR> =20
context.setVariable("nsActual",=20
nsActual); =20
=20
<BR> =20
System.out.println("nombreActual: " +=20
nombreActual); =
<BR> =20
=20
System.out.println("slActual: " + slActual);<BR> =20
=20
System.out.println("nsActual: " + nsActual);<BR> =20
=20
}<BR>%> =20
<BR><BR>For =
this last=20
code I get some sort of cast exception, I believe, when trying to =
access the=20
variables set in the map as "String" elements.<BR>Any hints?, I'm so=20
frustrated because I KNOW I did this before.<BR><BR>Thanks in=20
advance,<BR> &=
nbsp; & nbsp; & n=
bsp; &n bsp; =20
Juan Pedro<BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000E_01C83D67.F673F720--
Re: Getting a variable which name is the content of another. [message #38009 is a reply to message #37979] |
Thu, 13 December 2007 10:11  |
<html>
<head>
</head>
Excelent Paul, thanks for your help. <br>
I will give this a try as soon as I get my eclipse back on track
(suddenly stop working as expected).<br>
Regards,<br>
Juan Pedro<br>
<br>
Paul Elder escribió:
<blockquote cite="mid:fjreii$oc3$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta content="MSHTML 6.00.2900.3199" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Jaun Pedro:</font></div>
<div> </div>
<div><font face="Arial" size="2">From you messages, I'm guessing that
one JET variable contains the name of the other, and you are trying to
resolve the indirect reference.</font></div>
<div> </div>
<div><font face="Arial" size="2">So, given that you know $packageName
contains a variable name (in this instance 'schemaLocation'), how do
you get the value of that variable?</font></div>
<div> </div>
<div><font face="Arial" size="2">The trick it to use 'dynamic' XPath
expressions (XPath expresssions enclosed in { } ) in a select
attribute. At runtime, dynamic expressions are resolved into string
values prior to being passed to the tag handler. (Normally, XPath
expressions in select and test attributes should not be surrounded by {
and } ). Remember that a select attribute must contain a valid XPath
expression AFTER any dynamic expressions have been resolved.</font></div>
<div> </div>
<div><font face="Arial" size="2">So, in your case, you want the XPath
expression: $schemaLocation</font></div>
<div> </div>
<div><font face="Arial" size="2">But, the variable name
'schemaLocation' is the value of another variable, $packageName. So
write: ${$packageName}</font></div>
<div> </div>
<div><font face="Arial" size="2">Example:</font></div>
<div> </div>
<div><font face="Arial" size="2"><c:get
select="${$packageName}"/></font></div>
<div> </div>
<div><font face="Arial" size="2">will result in 'namespaceURI'</font></div>
<div> </div>
<div><font face="Arial" size="2">Note that the expansion of dynamic
XPath expression is not recursive, so that trying to do another level
in indirection in a single select attribute will not work. So:</font></div>
<div> </div>
<div><font face="Arial" size="2">c:get
select="${${$packageName}}"/></font></div>
<div> </div>
<div><font face="Arial" size="2">would NOT return the value of the
variable $nameSpaceURI. Instead, it will likely result in a XPath
expression compilation error.</font></div>
<div> </div>
<div><font face="Arial" size="2">Hope this helps,</font></div>
<div> </div>
<div><font face="Arial" size="2">Paul</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Juan Pedro Silva" <<a moz-do-not-send="true"
href="mailto:jpsilvagallino@gmail.com">jpsilvagallino@gmail.com</a>>
wrote in message <a moz-do-not-send="true"
href="news:fjpbhh$9ps$1@build.eclipse.org">news:fjpbhh$9ps$1@build.eclipse.org</a>...</div>
Hi everybody.<br>
<br>
<br>
width="1032">
<tbody>
<tr>
</td>
</td>
</tr>
<tr>
</td>
</tr>
</tbody>
</table>
<br>
<c:setVariable
<br>
I also tried:<br>
{ <br>
String slActual =
String nsActual =
<br>
nombreActual); <br>
}<br>
%> <br>
<br>
<br>
Juan Pedro<br>
</blockquote>
</blockquote>
</body>
</html>
Current Time: Sat Aug 02 04:17:44 EDT 2025
Powered by FUDForum. Page generated in 0.06646 seconds
