Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Adding Interpreter without any libraries
Adding Interpreter without any libraries [message #37899] Thu, 04 June 2009 02:24 Go to next message
I am using eclipse 3.4.1 with S1.0M4 DLTK .
In my IDE whenever we add a new interpreter (fssdbg.exe) through
interpreter preference page,it throws an expception "Failed to resolve
library locations for fssdbg.exe " and gives stack trace for
"java.lang.Exception: Output:".
Here we observed that whenever we add an interpreter it tries to run the
file returned by method "createPathFile" of
AbstractInterpreterInstallType and try to resolve the library locations.
but in our case we require no libraries with our interpreter.Is there any
mechanism by which we can remove this library resolving part or handle the
errors if no libraries found?
Please Help
Sheela
Re: Adding Interpreter without any libraries [message #37933 is a reply to message #37899] Thu, 04 June 2009 03:29 Go to previous message
Hi Sheela,
E.g. you can override
public synchronized LibraryLocation[] getDefaultLibraryLocations( final
IFileHandle installLocation,
EnvironmentVariable[] variables,
IProgressMonitor monitor)
and return empty array.
I think this DLTK part should be improved, but most probably it would
happen after 1.0 release.
Alex
Sheela wrote:
> any mechanism by which we can remove this library resolving part or
> handle the errors if no libraries found?
> Please Help
> Regards
> Sheela
Previous Topic:[BUILD] S-1.0RC2a-200905280900
Next Topic:Replace ExpressionList
Current Time: Mon Jul 14 03:09:45 EDT 2025
Powered by FUDForum. Page generated in 0.35326 seconds
