Re: [buckminster-dev] Getting started [message #3271] |
Wed, 13 February 2008 09:49  |
Thanks for the quick reply Thomas,
The firewall could very well be the issue...
If you do get a chance to change the URLs to something that we
'port-challenged' corporate citizens are able to access, that would be
great! :)
I'll try again later, just in case it is a glitch as you also suggested.
Todd
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
02/13/2008 09:42 Re: [buckminster-dev] Getting
AM started
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
I don't think you're doing anything wrong. If you get that far, your
Subclipse client is working as
it should. Are you by any chance behind a firewall? The demo as it stands
now are using the svn://
url's and I know that this has caused some problems earlier.
Another reason could be some temporary glitch at dev.eclipse.org. I know
they have had some issues
over the last couple of days. The demo works just fine for me right now. I
just tried it.
I'll look into changing the demo URL's to http later today.
Thomas Hallgren
Todd_Lee@amis.com wrote:
> Hi there,
> So I'm just getting my feet wet with Buckminster - we're looking to use
it
> with our uber-build system ;)
> Right out of the gate looks like I've hit a stumbling block...
> I'm running the eclipse SDK 3.3 with both buckminster and subclipse from
> the respective update sites.
> I tried the Hello World XML example, opening the CQUERY at the url given,
> then clicking 'Resolve to Wizard' to see what's going on:
> Error dialog message:
> org.tigris.subversion.svnclientadapter.SVNClientException:
> org.tigris.subversion.javahl.ClientException: No connection could be made
> because the target machine actively refused it.
> svn: Can't connect to host 'dev.eclipse.org': No connection could be made
> message in console: (DEBUG level)
> Found searchPath default for component org.demo.hello.xml.world
> ERROR [0001] : No suitable provider for component
> org.demo.hello.xml.world:osgi.bundle was found in searchPath default
> ERROR [0001] : Provider
svn( svn://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster/ trunk/org.eclipse.buckminster/demo/org.demo.hello.xml.world):
> No match found for component org.demo.hello.xml.world
> We use CVS, so it could be that I've run into this a problem as an svn
> newbie, but can you confirm that I should be able to access the sample
> files?
> If that's not the problem, any suggestions?
> Thanks
> Todd
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or
privileged. The information is intended for the use of the individual or
entity named above. If you are not the intended recipient, please be aware
that any disclosure, copying, distribution or use of the contents of this
information is prohibited. If you received this electronic message in
error, please notify the sender and delete the copy you received.
_______________________________________________
buckminster-dev mailing list
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Re: [buckminster-dev] Getting started [message #3303 is a reply to message #3271] |
Wed, 13 February 2008 10:17  |
Right now it will not work. I changed to http but it turns out that during our move from being a
technology sub-project to become a tools sub-project, http access was disabled. I've contacted the
Webmaster about this and I hope it will be fixed soon.
Stay tuned,
- thomas
> great! :)
> Todd
FUDForum. Page generated in 0.03913 seconds
