| AJDT 1.1.10 Samples problem with Eclipse 3.0 [message #37837] |
Wed, 30 June 2004 18:45  |
Originally posted by: eric.clairambault.free.fr
I'm facing the following problem when building any of the AJDT 1.1.10
samples :
Internal compiler error
java.lang.NoSuchMethodError: org.apache.bcel.generic.InstructionFactory:
method
createNewArray(Lorg/apache/bcel/generic/Type;S)Lorg/apache/b cel/generic/Instruction;
not found
I tryed IBM JDK 1.4.1 and Sun JDK 1.4.1_05.
Does anyone found a similar problem ?
Thanks for your help.
| Re: AJDT 1.1.10 Samples problem with Eclipse 3.0 [message #37972 is a reply to message #37837] |
Fri, 02 July 2004 05:43  |
Eric Clairambault wrote:
> samples :
> method
> not found
Sorry, don't mind.
I've found the solution on bugzilla (bugs 66222, 59921). So, I've moved to
Sun JDK 1.4.2.
| Re: AJDT 1.1.10 Samples problem with Eclipse 3.0 [message #581145 is a reply to message #37837] |
> samples :
> method
> not found
Sorry, don't mind.
Sun JDK 1.4.2.
FUDForum. Page generated in 0.05430 seconds
