ANT optional task in the WSAD 5 [message #37809] |
Mon, 19 May 2003 10:10  |
Originally posted by: Francis.Li.fmr.com
I would like to use some optional task in the ANT for ftp the ear file and
telnet to other machine to install ear file. I am using WSAD5 (eclipse 2).
I have checked the optional.jar file inclided in the ANT plugin, it is
there in the plugin directory and plugin.xml. but the eclipse couldn't
find it. Any suggestion ?
Error I got ....
Arguments: -Dbasedir=C:\wsad5\workspace\simple
Build exception: C:\wsad5\workspace\simple\PM\build.xml:37: Could not
create task of type: ftp. Common solutions are to use taskdef to declare
your task, or, if this is an optional task, to put the optional.jar in the
lib directory of your ant installation (ANT_HOME).
C:\wsad5\workspace\simple\PM\build.xml:37: Could not create task of type:
ftp. Common solutions are to use taskdef to declare your task, or, if this
is an optional task, to put the optional.jar in the lib directory of your
at org.apache.tools.ant.UnknownElement.makeTask(UnknownElement. java:153)
org.apache.tools.ant.UnknownElement.maybeConfigure(UnknownEl ement.java:83)
at org.apache.tools.ant.Task.perform(Task.java:216)
at org.apache.tools.ant.Target.execute(Target.java:184)
at org.apache.tools.ant.Target.performTasks(Target.java:202)
at org.apache.tools.ant.Project.executeTarget(Project.java:601)
at org.apache.tools.ant.Project.executeTargets(Project.java:560 )
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:262)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:234)
org.eclipse.ui.externaltools.internal.core.AntFileRunner.exe cute(AntFileRunner.java:56)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.executeRunner(DefaultRunnerContext.java:428)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.run(DefaultRunnerContext.java:479)
org.eclipse.ui.externaltools.internal.ui.AntLaunchWizard$1.r un(AntLaunchWizard.java:117)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
Re: ANT optional task in the WSAD 5 [message #38203 is a reply to message #37809] |
Mon, 19 May 2003 12:42  |
Originally posted by: darin_swanson.oti.com
Are you using a taskdef?
Are you adding the task using the Tasks preference page?
What does your build file look like?
You must define optional tasks. See the Ant or Eclipse documentation for
more details.
HTH
Darins
"Francis Li" <Francis.Li@fmr.com> wrote in message
news:baaolh$723$1@rogue.oti.com...
> Error I got ....
> at
> at
va:262)
> at
er.java:56)
> at
> at
> at
rd.java:117)
> at
..java:98)
FUDForum. Page generated in 0.03234 seconds
