Home » Archived » M2M (model-to-model transformation) » [ATL] how to find an already generated element in non-declarative rules ?
[ATL] how to find an already generated element in non-declarative rules ? [message #37805] Tue, 15 May 2007 04:46 Go to next message
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi All,
I'm stuck with a simple (?) problem: I want to transform a model (MA)
that conforms to a home-made metamodel (MMA) into another model that
conforms to eCore.
In my MMA, I have an element that can be combined with itself (i.e.
Element has a collection of <Element> called 'elements').
I want to transform these elements into EClass, so I have a declarative
rule that takes a Element in its 'from' clause and produce a EClass in
its 'to' clause.
But now I want the collection 'elements' to become a EReference in the
target model.
Because there is no corresponding entity in my source model, I can not
create a declarative rule for this transformation.
So I have added a called rule that create the new EReference, but I
can't see how to find the target of my EReference, which must be an
already generated EClass...
I understand that ATL can find target elements from the input elements,
but I think this can work only for declarative rules ??
Please Help !
Thanks in advance,
Sylvain
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37935 is a reply to message #37805] Tue, 15 May 2007 09:58 Go to previous messageGo to next message
Ok forget it,
In my called rule that create EReference, I'have added a parameter that
is the eType of eReference. As the rule is called from a declarative
rule, ATL is able to find the correct target element.
> Hi All,
> I'm stuck with a simple (?) problem: I want to transform a model (MA) that
> conforms to a home-made metamodel (MMA) into another model that conforms to
> eCore.
> In my MMA, I have an element that can be combined with itself (i.e. Element
> I want to transform these elements into EClass, so I have a declarative rule
> that takes a Element in its 'from' clause and produce a EClass in its 'to'
> clause.
> But now I want the collection 'elements' to become a EReference in the target
> model.
> Because there is no corresponding entity in my source model, I can not create
> So I have added a called rule that create the new EReference, but I can't see
> how to find the target of my EReference, which must be an already generated
> EClass...
> I understand that ATL can find target elements from the input elements, but I
> Please Help !
> Thanks in advance,
> Sylvain
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37969 is a reply to message #37805] Tue, 15 May 2007 10:00 Go to previous messageGo to next message
Originally posted by: rchevrel.sodius.com
--------------030309010002050208030700
Hi Sylvain,
I cannot completely understand your problem but I think this code could
help you.
rule root {
from
in_elm1 : MMa!Element
to
out_elm1 : ECore!EClass ()
rule elements {
from
-- you match a relation
e1 : MMa!Element,
e2 : MMA!Element (
e1.elements->includes(e2)
to
out_elm1 : ECore!EReference (
-- you attach this element with its parent
eContainer <- e1
out_elm2 : ECore!EReference (
eContainer <- e2,
-- you set the opposite
eOpposite <- out_elm1
You could also use a lazy rule.
Please send a concrete example if you have some problems.
*R
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37999 is a reply to message #37969] Tue, 15 May 2007 10:17 Go to previous messageGo to next message
Hi Regis,
With your code I think I can remove the called rule ! I did not see
this tips to match the relation.
thanks
Sylvain
> Hi Sylvain,
> I cannot completely understand your problem but I think this code could help
> you.
> rule root {
> from
> to
> rule elements {
> from
> e1 : MMa!Element,
> e2 : MMA!Element (
> to
> eContainer <- e1
> eContainer <- e2,
> *Régis CHEVREL* <mailto:rchevrel@sodius.com>
> SODIUS*
> *6, rue Cornouaille
> 44319 Nantes - France
> Phone: +33 (0)2 28 23 54 34
> ***www.mdworkbench.com* <http://www.mdworkbench.com/>* *
> Draw more value from your model
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38059 is a reply to message #37969] Tue, 15 May 2007 11:48 Go to previous messageGo to next message
Hi Régis
> Hi Sylvain,
> you.
> rule root {
> from
> to
> rule elements {
> from
> e1 : MMa!Element,
> e2 : MMA!Element (
> to
> eContainer <- e1
Unfortunately this doesn't work as eContainingClass from MOF is not
modifiable. It seems that a newly created EReference cannot be attached
to another EClassifier like that. I must explicitly add it to
eStructuralFeatures features of the EClass :-(
> eContainer <- e2,
> SODIUS*
> *6, rue Cornouaille
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38125 is a reply to message #38059] Tue, 15 May 2007 12:22 Go to previous messageGo to next message
Hello Sylvain,
>> rule elements {
>> from
>> e1 : MMa!Element,
>> e2 : MMA!Element (
>> to
>> eContainer <- e1
Being able to navigate and set references in both directions is *very*
useful in model transformation, especially when using a declarative style.
Here is an excerpt of a slide on metamodeling hints that I give to students:
* Define bidirectional associations (i.e., pairs of references)
=> Makes the model easier to navigate and populate
It seems that Ecore was not designed by model transformation developers :-).
A quick and dirty (i.e., imperative) way to solve your problem would be
to add an action block to rule "elements" to perform the setting in the
opposite direction:
do {
e1.eStructuralFeatures <- out_elm1;
Frédéric Jouault
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38157 is a reply to message #38125] Tue, 15 May 2007 12:30 Go to previous messageGo to next message
Hi again,
> Hello Sylvain,
> >> rule elements {
> >> from
> >> e1 : MMa!Element,
> >> e2 : MMA!Element (
> >> to
> >> eContainer <- e1
> Being able to navigate and set references in both directions is *very* useful
I agree with you on that point ;-)
> A quick and dirty (i.e., imperative) way to solve your problem would be to
> add an action block to rule "elements" to perform the setting in the opposite
> direction:
> do {
well, I dont understand that: e1 refers to my input model, so it
doesn't have the eStructuralFeatures ! In order to do this I must get
the generated target eClass and I think it's bad ;-)
do
giveMeTheGeneratedEClassFor(e1).eStructuralFeatures <- out_elm1;
should solve my problem ;-)
> Best regards,
> Frédéric Jouault
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38258 is a reply to message #38157] Tue, 15 May 2007 12:46 Go to previous messageGo to next message
Hello again,
>> be to add an action block to rule "elements" to perform the setting in
>> the opposite direction:
>> do {
> well, I dont understand that: e1 refers to my input model, so it doesn't
> have the eStructuralFeatures ! In order to do this I must get the
> do
Of course, you are right. I so much focused on the reverse setting part
of the issue that I missed this ;-).
giveMeTheGenerated<something>For is called resolveTemp in ATL.
This case is one of the rare cases when we are going to actually use
resolveTemp to resolve to the default target element (because we are
doing it in an imperative block):
do {
thisModule.resolveTemp(e1, 'out_elm1').eStructuralFeatures <- out_elm1;
Frédéric Jouault
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38324 is a reply to message #38258] Tue, 15 May 2007 13:10 Go to previous messageGo to next message
> Hello again,
> >> do {
> > do
> Of course, you are right. I so much focused on the reverse setting part of
> resolveTemp to resolve to the default target element (because we are doing it
> do {
Well I tried this and I get an EmptyStackException... I dont understand
why: every elements should have been created at this time ?
> Best regards,
> Frédéric Jouault
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38422 is a reply to message #38324] Tue, 15 May 2007 13:21 Go to previous messageGo to next message
>> Hello again,
>> >> do {
>> > do
>> do {
> Well I tried this and I get an EmptyStackException... I dont understand why:
OK my mistake: the second parameter of resolveTemp should be set to the
same name as the one specified in the rule used to create the parent
element ! in my case it was 'class' rather than 'out_elm1'.
Thanks for your help Frédéric ;-)
>> Best regards,
>> Frédéric Jouault
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38488 is a reply to message #38422] Tue, 15 May 2007 16:35 Go to previous message
Well, the example was confusing because both rules used the same target
element name in Régis' original example (note that I do not blame him: I
would have done exactly the same thing ;-)).
You are welcome.
Frédéric Jouault
Previous Topic:[ATL] how to keep reference to source Model in target model
Next Topic:Composite Class
Current Time: Tue May 13 18:10:43 EDT 2025
Powered by FUDForum. Page generated in 0.10694 seconds
