Home » Modeling » GMF (Graphical Modeling Framework) » top-level vs. inner edit parts
top-level vs. inner edit parts [message #37782] |
Mon, 04 September 2006 04:24  |
I'm working on an editor for a hierarchical diagram, similar to a
process diagram. In the mapping model, I've declared the top-level
node references and mappings and the child node references refer to
the top-level ones. I think the model is correct, since the editor
logic seems to work well. I'm really impressed with what the generator
gives for free, once the models are worked out. It's a lot more fun
modelling than programming.
I do, however, need som custom code for both shapes and edit parts,
and this leads to some problems. Since there are essentially two
definitions of most nodes types, both as top-level objects and as
children, most node types result in two edit part classes, e.g.
ComputationEditPart and Computation2EditPart. Whenever I introduce
custom code, I have to insert it into two classes. In addition,
provider kind of classes, like ModelingAssistantProvider, refer to
these and become fairly complex although the model isn't that complex.
What I would like is to express some place that there is no need for
two versions of the same concept, e.g. ComputationEditPart ==
Computation2EditPart for all practical purposes. My current strategy
is to edit Computation2EditPart so that it extends ComputationEditPart
and adds little extra logic, but I'm not sure if this results in other
problems. This does not solve the problem with the generated
ModelingAssistantProvider, which refers to both ComputationEditPart
Comments? Suggestions?
Hallvard
Re: top-level vs. inner edit parts [message #38098 is a reply to message #37782] |
Mon, 04 September 2006 07:01   |
You can avoid code duplication for shapes if you generate them into
standalone plug-in (i.e. not placing them as inner classes of EditPart, as
it happens by default).
For EditParts, you could try to have your own subclass between generated
code and runtime code, so you'll need to update only 'extends' clause for
both ComputationEditPart and Computation2EditPart
Artem
"Hallvard Tr?tteberg" <hal@idi.ntnu.no> wrote in message
news:6llnf29sf90vfd5p8kf1gd2s3g985eoc1o@4ax.com...
> Hallvard
Re: top-level vs. inner edit parts [message #38168 is a reply to message #38098] |
Mon, 04 September 2006 07:34  |
On Mon, 4 Sep 2006 13:01:28 +0200, "Artem Tikhomirov"
>Artem
You're thinking of introducing an AbstractComputationEditPart and make
both ComputationEditPart and Computation2EditPart inherit from this
class. Good idea, at least it solves the problem of code sharing for
non-generated methods, like refreshing and anchor handling.
Still, the distinction between ComputationEditPart and
Computation2EditPart seems meaningless in my specific case (not in
general, I agree).
Hallvard
>> Hallvard
Current Time: Thu Jul 17 11:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.12221 seconds
