Multiple use of DataSet -> Image lost [message #368993] |
Thu, 16 July 2009 10:09 |
Originally posted by: jst.ivyteam.ch
Hy,
I have a scripted Data Set which I use twice in a report. In the first
part I create a selfmade Table of contents, and in the second part I
fetch the actual detailed information out of the dataset. There is also
an Image in this Dataset which should be displayed in the second part.
However, this Image will not be displayed in a html & pdf report. But
when I remove my TOC (the first part) it works fine. So I assume there
is something wrong when a datasource is used twice within a report... at
least with the images.
The pdf emmiter at least gives me some hints whats wrong:
Jul 16, 2009 11:56:12 AM
org.eclipse.birt.report.engine.layout.pdf.emitter.ConcreteIm ageLayout
getSpecifiedDimension
SEVERE: null
SEVERE: null
Anybody an idea why this happens or what the problem is?
I use Birt 2.3.2.
Thx!
Jacques
Re: Multiple use of DataSet -> Image lost [message #369007 is a reply to message #368993] |
Fri, 17 July 2009 15:43 |
Originally posted by: jasonweathersby.windstream.net
Jacques,
Can you make a copy of the scripted data set and try using the copy for
the second query?
Jason
Jacques wrote:
> Hy,
> SEVERE: null
> SEVERE: null
> I use Birt 2.3.2.
> Thx!
> Jacques
Re: Multiple use of DataSet -> Image lost [message #369018 is a reply to message #369007] |
Mon, 20 July 2009 06:44 |
Well, yes, thats actually what I am doing.
But I wondered if there weren't a more elegant solution...
However, thanks!
Jacques
Jason Weathersby schrieb:
> Jacques,
> the second query?
> Jason
> Jacques wrote:
>> Hy,
>> also an Image in this Dataset which should be displayed in the second
>> part.
>> at least with the images.
>> SEVERE: null
>> SEVERE: null
>> I use Birt 2.3.2.
>> Thx!
>> Jacques
FUDForum. Page generated in 0.03173 seconds
