Re: How to run a BIRT report in background [message #368982 is a reply to message #368978] |
Wed, 15 July 2009 15:23 |
Originally posted by: johnw.innoventsolutions.com
Anand,
This is going to depend. If you are upgrading to Actuate 9, 10, or
iServer Express, this functionality will remain unchanged. If you are
just running the BIRT report engine standalone, then it is up to you to
do this. I would recommend that you schedule them using Scheduled Jobs
or AT if your on Windows, or as a background process or using a cronjob
using *nix.
John
Anand wrote:
> Currently we run our reporting application with Actuate 8. user can
> choosse different Ad-hoc reports and then select different options
> (parameters for a sql procedure), and submit the Job and log out. The
> Job runs in background for few hours and then emails the user for
> success or failure, with the csv report location if a success.
> when we planned to replace the reporting tool with BIRT, i found many
> things identical which can be replaced but i was not able to find a way
> to have the BIRT reports run in background when an user submits a query
> and logs out.
> Can anyone please help me with this? Is there any functionalit with BIRT
> which i can use to have multiple reports run in background once users
> submit the Job and logout?
> Thanks a bunch!!
Re: How to run a BIRT report in background [message #368987 is a reply to message #368985] |
Wed, 15 July 2009 23:44 |
Actually, no, I usually roll my own.
There is iServer Express, which is not free or open source. Its
everything youve come to expect from iServer, except it only supports
BIRT and eSpreadsheet, and is much cheaper.
I don't know off hand, but maybe Pentaho. I haven't used it personally,
but I know they have BIRT integrated in it, I just don't know if they
support scheduling jobs.
John
Anand wrote:
> Thanks John for the info. Are yo aware of any open source tool that can
> be integrated with BIRT to achieve the Job scheduling monitoring
> functionality, similar to that of ISERVER for Actuate.
> Anand
FUDForum. Page generated in 0.03131 seconds
