Image Maps in Reports? [message #368876] |
Thu, 02 July 2009 12:54 |
Originally posted by: jst.ivyteam.ch
is there a way to create image maps (e.g.
http://en.wikipedia.org/wiki/Image_map) in Birt reports?
And is it possible to do this from a Scripted Data Source, by providing
for a picture the hyperlinks and coordinates which should contain the links.
The only possibility I currently see is to generate and save pictures
before the report generation, and then, to have a imagemap in the
report, pass the image address, and the various links & coordinates of
each mapping through the data source. And with this data create a
dynamic text that consists of the actual html code to do this...
But I suppose this won't work work in PDF nor in DOC...
Any other, better ideas?
Jacques
Re: Image Maps in Reports? [message #368903 is a reply to message #368876] |
Sat, 04 July 2009 07:28 |
Originally posted by: johnw.innoventsolutions.com
Yes, this is how the chart engine does its interactivity as a matter of
fact.
If you wanted to do this in a report, you would need to use a Text data
element, and set the type to HTML. Then you can set your coordinates
from a data source using the VALUE-OF tag in the text element. Its a lot
of coding and planning, but it can be done. If it is interacting with
elements in the report itself, just be sure to set their bookmarks
accordingly to use in the document.getElementById call.
It won't work in any client that doesn't support Javascript on the
client, so probably not in PDF or DOC.
Jacques wrote:
> Hello,
> links.
> Jacques
FUDForum. Page generated in 0.02797 seconds
