Re: master page - dynamic header [message #368879 is a reply to message #368855] |
Thu, 02 July 2009 14:22 |
Originally posted by: jasonweathersby.windstream.net
Tero,
Have you looked at the new and notable for 2.5. There is a section in
it that describes page variables and scripts. This most likely could be
used in your case.
Jason
Tero wrote:
> Hello,
> I am building a report to be seen with the viewer and downloaded as ppt.
> I set every "slide" with a page-break in the grid which is the frame for
> each page.
> Is it possible to have the header dynamicly built page by page (slide by
> slide, always different)?
> The reason is that for one of the slides, the table inside it may (or
> may not) be bigger than the page/slide and complete in the next (in the
> case it is). Therefore if I use labels at the top of every page instead
> of a header, for this overrun-page there is no header. Even worse: I
> have a background image which gets covered unsightly, because the
> overrun table starts at the top of the page.
> Many Thanks,
> Tero
FUDForum. Page generated in 0.03026 seconds
