BIRT Bug? [message #368746] |
Tue, 23 June 2009 20:51 |
Originally posted by: ddd.asd.com
I have installed:
eclipse
Version: 3.4.2
Build id: M20090211-1700
on vista 64. I have installed the latest version of BIRT. When I create a
report and try to edit the data source (double click the added data source)
I get the error:
An error has occurred. See error log for more details.
org.eclipse.datatools.connectivity.oda.design.ui.designsessi on.DataSourceDesignSession.setAndVerifyUseProfileSelectionPa ge()Z
I have looked in the error log under the Plug-in Development perspective
where I get the following info:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
java.lang.NoSuchMethodError:
org.eclipse.birt.report.designer.data.ui.datasource.DataSour ceEditor.addCustomPageODAV3(DataSourceEditor.java:122)
org.eclipse.birt.report.designer.data.ui.datasource.DataSour ceEditor. <init>(DataSourceEditor.java:78)
org.eclipse.birt.report.designer.internal.ui.views.data.prov iders.DataSourceNodeProvider.performEdit(DataSourceNodeProvi der.java:84)
org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:410)
org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:85)
org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:66)
org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:214)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Any idea on how to solve this problem without reinstalling eclipse? I have
posted this in the eclipse.newcomer since it might also be a bug in eclipse.
FUDForum. Page generated in 0.03328 seconds
