landscape masterpage problem in word emitter [message #368547] |
Tue, 09 June 2009 10:10 |
Conor O'Mahony Messages: 108 Registered: July 2009 |
--------------020902090909080304070803
I have a report design with 2 masterpages, one portrait and one landscape. The masterpages work fine
when I generate a PDF document from the design, but when I generate a Word document from the same
design, the landscape masterpage is not applied correctly. The page does actually appear in
landscape orientation, but the header and footer content is from the portrait masterpage.
I have attached the report design, the pdf output which has the landscape master page correctly
applied (text in header in landscape page says "landscape"), and the word output which is incorrect
(text in header in landscape page says "portrait", width of header and footer is incorrect).
Does anyone know how to fix this, or even a workaround? The content of the header and footers in
both masterpages is the same, so even if i could just make the width of the header/footer the
correct width for the landscape page in the doc output, this would help.
Eclipse is 3.4.1
Birt is 2.3.1
Many thanks,
Conor
Content-Type: text/xml;
name="test.rptdesign"
Content-Disposition: inline;
filename="test.rptdesign"
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.1.v20080911 Build <2.3.1.v20080917-1340></property>
<property name="units">in</property>
<simple-property-list name="includeResource">
<value>resources/report</value>
</simple-property-list>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="eventHandlerClass"> com.pilz.ie.pascal.report.core.logic.impl.birt.eventhandlers .PAScalReportEventAdapter </property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<script-data-source name="scripted" id="203"/>
<script-data-source name="Data Source" id="1273"/>
</data-sources>
<data-sets>
<script-data-set name="librariesUsed" id="204">
<property name="eventHandlerClass"> com.pilz.ie.pascal.report.core.logic.impl.birt.eventhandlers .LibrariesUsedDataSetEventHandler </property>
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">name</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">1</property>
<property name="name">version</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">date</property>
<property name="dataType">date-time</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">name</property>
</structure>
<structure>
<property name="columnName">version</property>
</structure>
<structure>
<property name="columnName">date</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="position">3</property>
</structure>
</list-property>
</structure>
<property name="dataSource">scripted</property>
</script-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
<style name="tool-title" id="18">
<property name="fontWeight">bold</property>
<property name="color">#000000</property>
<property name="textUnderline">underline</property>
<property name="textAlign">right</property>
</style>
<style name="right_image" id="21">
<property name="backgroundPositionX">0%</property>
<property name="paddingTop">0pt</property>
<property name="paddingLeft">0pt</property>
<property name="paddingBottom">0pt</property>
<property name="paddingRight">0pt</property>
<property name="whiteSpace">nowrap</property>
<property name="display">inline</property>
</style>
<style name="headerText" id="115">
<property name="textAlign">center</property>
<property name="verticalAlign">bottom</property>
</style>
<style name="center-link" id="186">
<property name="color">blue</property>
</style>
<style name="centerText" id="298">
</style>
<style name="leftText" id="299">
<property name="textAlign">left</property>
</style>
<style name="inline" id="709">
</style>
<style name="gridHeadingRowGen" id="748">
<property name="backgroundColor">#FFB300</property>
</style>
<style name="table_detail_font" id="749">
<property name="fontSize">small</property>
</style>
<style name="bugfix" id="1058">
</style>
<style name="gridItemWithBorderGen" id="1203">
<property name="borderBottomWidth">thin</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopWidth">thin</property>
<property name="paddingTop">1pt</property>
<property name="paddingLeft">1pt</property>
<property name="paddingBottom">1pt</property>
<property name="paddingRight">1pt</property>
</style>
<style name="gridItemHeadingWithBorderGen" id="1204">
</style>
<style name="gridCellNoPadding" id="1207">
</style>
<style name="gridDetailRowOddGen" id="1212">
<property name="backgroundColor">#E9FFE9</property>
</style>
<style name="gridDetailRowEvenGen" id="1213">
<property name="backgroundColor">#FFFFE9</property>
</style>
<style name="report" id="1214">
<property name="fontFamily">sans-serif</property>
</style>
<style name="gridStyleGen" id="1215">
</style>
<style name="sectionHeadingGen" id="1216">
<property name="backgroundColor">#D3D3D3</property>
<property name="fontSize">larger</property>
</style>
<style name="sectionHeading2Gen" id="1217">
</style>
</styles>
<page-setup>
<simple-master-page name="MasterPagePortrait" id="416">
<property name="type">a4</property>
<property name="orientation">portrait</property>
<property name="topMargin">0.5in</property>
<property name="leftMargin">0.5in</property>
<property name="bottomMargin">0.5in</property>
<property name="rightMargin">0.5in</property>
<property name="backgroundImage">resources\images\demo.gif</property >
<property name="backgroundPositionX">center</property>
<property name="backgroundPositionY">center</property>
<property name="backgroundRepeat">no-repeat</property>
<page-header>
<grid name="headerGridPortrait" id="6">
<property name="style">right_image</property>
<property name="fontSize">medium</property>
<property name="marginTop">0pt</property>
<property name="width">100%</property>
<column id="7"/>
<column id="8"/>
<column id="9"/>
<row id="10">
<cell id="11">
</cell>
<cell id="12">
<text name="headerText" id="197">
<property name="eventHandlerClass"> com.pilz.ie.pascal.report.core.logic.impl.birt.eventhandlers .HeaderFooterEventHandler </property>
<property name="style">headerText</property>
<property name="contentType">plain</property>
</text>
</cell>
<cell id="13">
</cell>
</row>
<row id="193">
<cell id="194">
<property name="verticalAlign">middle</property>
</cell>
<cell id="195">
<text name="incompleteTextPortrait" id="1271">
<text-property name="content"><![CDATA[Incomplete draft report
Do not use for certificationPORTRAIT]]></text-property>
</text>
</cell>
<cell id="196">
<image name="headerImagePortrait" id="1132">
<property name="style">inline</property>
<property name="height">35px</property>
<property name="width">100px</property>
<property name="source">embed</property>
<property name="imageName">smallpilzlogo.png</property>
</image>
<label id="1057">
<property name="style">bugfix</property>
</label>
</cell>
</row>
<row id="1184">
<property name="height">0.2in</property>
<property name="backgroundColor">#FFFFFF</property>
<cell id="1185">
</cell>
<cell id="1186">
</cell>
<cell id="1187">
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid id="91">
<property name="backgroundColor">silver</property>
<column id="92">
<property name="width">2.3854166666666665in</property>
</column>
<column id="93">
<property name="width">2.3958333333333335in</property>
</column>
<column id="94"/>
<row id="1188">
<cell id="1189"/>
<cell id="1190"/>
<cell id="1191"/>
</row>
<row id="95">
<cell id="96">
<text name="pascalVersion" id="192">
<text-property name="content" key="GenerateReportAction_PAScal_version"><![CDATA[]]></text-property >
</text>
</cell>
<cell id="97">
<text name="footerText" id="112">
</text>
</cell>
<cell id="98">
<grid id="1134">
<column id="1135">
<property name="width">1.3020833333333333in</property>
</column>
<column id="1136"/>
<column id="1137"/>
<column id="1138"/>
<row id="1139">
<cell id="1140">
<label name="pageNumberSpaceLabel" id="1144"/>
</cell>
<cell id="1141">
<auto-text id="106">
<property name="type">page-number</property>
</auto-text>
</cell>
<cell id="1142">
<text id="108">
<text-property name="content"><![CDATA[/]]></text-property>
</text>
</cell>
<cell id="1143">
<auto-text id="110">
<property name="type">total-page</property>
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
<row id="188">
<cell id="189">
<text id="111">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</cell>
<cell id="190"/>
<cell id="191"/>
</row>
</grid>
</page-footer>
</simple-master-page>
<simple-master-page name="NewSimpleMasterPage" id="1218">
<property name="orientation">landscape</property>
<page-header>
<grid name="headerGridLandscape" id="1219">
<property name="width">10.693in</property>
<column id="1220"/>
<column id="1221"/>
<column id="1222"/>
<row id="1223">
<cell id="1224">
</cell>
<cell id="1225">
<text name="headerText1" id="1226">
</text>
</cell>
<cell id="1227">
</cell>
</row>
<row id="1228">
<cell id="1229">
</cell>
<cell id="1230">
<text name="incompleteTextLandscape" id="1272">
Do not use for certificationLANDSCAPE]]></text-property>
</text>
</cell>
<cell id="1231">
<image name="headerImageLandscape" id="1232">
</image>
<label id="1233">
</label>
</cell>
</row>
<row id="1234">
<cell id="1235">
</cell>
<cell id="1236">
</cell>
<cell id="1237">
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid id="1238">
<column id="1239">
</column>
<column id="1240">
</column>
<column id="1241"/>
<row id="1242">
<cell id="1243"/>
<cell id="1244"/>
<cell id="1245"/>
</row>
<row id="1246">
<cell id="1247">
<text name="pascalVersion1" id="1248">
</text>
</cell>
<cell id="1249">
<text name="footerText1" id="1250">
</text>
</cell>
<cell id="1251">
<grid id="1252">
<column id="1253">
</column>
<column id="1254"/>
<column id="1255"/>
<column id="1256"/>
<row id="1257">
<cell id="1258">
<label name="pageNumberSpaceLabel1" id="1259"/>
</cell>
<cell id="1260">
<auto-text id="1261">
</auto-text>
</cell>
<cell id="1262">
<text id="1263">
</text>
</cell>
<cell id="1264">
<auto-text id="1265">
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
<row id="1266">
<cell id="1267">
<text id="1268">
</text>
</cell>
<cell id="1269"/>
<cell id="1270"/>
</row>
</grid>
</page-footer>
</page-setup>
<body>
<grid name="coverPage" id="148">
<property name="style">centerText</property>
<property name="masterPage">MasterPagePortrait</property>
<property name="pageBreakAfter">always</property>
<property name="height">9.7in</property>
<column id="149"/>
<row id="150">
<cell id="151">
<grid name="whiteSpaceGrid1" id="85">
<column id="86"/>
<row id="87">
<property name="height">3in</property>
<cell id="88">
<property name="canShrink">true</property>
</cell>
</row>
</grid>
</cell>
</row>
<row id="1194">
<cell id="1195">
<grid name="projectDetailsGridGen" id="1196">
<column id="1197"/>
<row id="1198">
<cell id="1199">
<grid id="1274">
<column id="1275"/>
<column id="1276"/>
<row id="1277">
<property name="height">0.1in</property>
<cell id="1278"/>
<cell id="1279"/>
</row>
<row id="1280">
<property name="style">gridHeadingRowGen</property>
<cell id="1281">
<label id="1282">
<text-property name="text">Project name</text-property>
</label>
</cell>
<cell id="1283">
<text id="1284">
<text-property name="content"><![CDATA[sample report]]></text-property>
</text>
</cell>
</row>
<row id="1285">
<cell id="1286">
<label id="1287">
<text-property name="text">Safety standard</text-property>
</label>
</cell>
<cell id="1288">
<text id="1289">
<text-property name="content"><![CDATA[EN ISO 13849-1(PL)]]></text-property>
</text>
</cell>
</row>
<row id="1290">
<cell id="1291">
<label id="1292">
<text-property name="text">Author</text-property>
</label>
</cell>
<cell id="1293">
<text id="1294">
<text-property name="content"><![CDATA[]]></text-property>
</text>
</cell>
</row>
<row id="1295">
<cell id="1296">
<label id="1297">
<text-property name="text">Company name</text-property>
</label>
</cell>
<cell id="1298">
<text id="1299">
</text>
</cell>
</row>
<row id="1300">
<cell id="1301">
<label id="1302">
<text-property name="text">Company address</text-property>
</label>
</cell>
<cell id="1303">
<text id="1304">
</text>
</cell>
</row>
<row id="1305">
<cell id="1306">
<label id="1307">
<text-property name="text">Version</text-property>
</label>
</cell>
<cell id="1308">
<text id="1309">
</text>
</cell>
</row>
<row id="1310">
<cell id="1311">
<label id="1312">
<text-property name="text">Creation date</text-property>
</label>
</cell>
<cell id="1313">
<text id="1314">
<text-property name="content"><![CDATA[09 June 2009 10:47:41 IST]]></text-property>
</text>
</cell>
</row>
<row id="1315">
<cell id="1316">
<label id="1317">
<text-property name="text">Last modified date</text-property>
</label>
</cell>
<cell id="1318">
<text id="1319">
<text-property name="content"><![CDATA[09 June 2009 10:54:26 IST]]></text-property>
</text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
<grid name="projectBodyGridGen" id="1208">
<column id="1209"/>
<row id="1210">
<cell id="1211">
<grid id="1320">
<column id="1321"/>
<row id="1322">
<cell id="1323">
<grid id="1324">
<property name="style">gridStyleGen</property>
<column id="1325"/>
<row id="1326">
<cell id="1327"/>
</row>
<row id="1328">
<property name="style">sectionHeadingGen</property>
<cell id="1329">
<label id="1330">
<text-property name="text">SRCF Overview</text-property>
</label>
</cell>
</row>
</grid>
</cell>
</row>
<row id="1331">
<cell id="1332">
<grid id="1333">
<column id="1334"/>
<column id="1335"/>
<column id="1336"/>
<column id="1337"/>
<column id="1338"/>
<column id="1339"/>
<row id="1340">
<cell id="1341"/>
<cell id="1342"/>
<cell id="1343"/>
<cell id="1344"/>
<cell id="1345"/>
<cell id="1346"/>
</row>
<row id="1347">
<cell id="1348">
<property name="style">gridItemWithBorderGen</property>
<label id="1349">
<text-property name="text">System/Module</text-property>
</label>
</cell>
<cell id="1350">
<label id="1351">
<text-property name="text">Target PL</text-property>
</label>
</cell>
<cell id="1352">
<label id="1353">
<text-property name="text">Result</text-property>
</label>
</cell>
<cell id="1354">
<label id="1355">
Re: landscape masterpage problem in word emitter [message #368643 is a reply to message #368547] |
Wed, 17 June 2009 08:52 |
Anyone have any help or any workaround on this?
Many thanks,
Conor
Conor O'Mahony wrote:
> landscape. The masterpages work fine when I generate a PDF document from
> the design, but when I generate a Word document from the same design,
> actually appear in landscape orientation, but the header and footer
> landscape master page correctly applied (text in header in landscape
> page says "landscape"), and the word output which is incorrect (text in
> incorrect).
> the header and footers in both masterpages is the same, so even if i
> could just make the width of the header/footer the correct width for the
> Eclipse is 3.4.1
> Birt is 2.3.1
> Many thanks,
> Conor
Re: landscape masterpage problem in word emitter [message #368648 is a reply to message #368643] |
Wed, 17 June 2009 13:52 |
Originally posted by: jasonweathersby.windstream.net
Conor,
Can you try this with one of the 2.5 builds just to check and see if the
bug has been fixed?
Jason
> Many thanks,
> Conor
>> does actually appear in landscape orientation, but the header and
>> Eclipse is 3.4.1
>> Birt is 2.3.1
>> Many thanks,
>> Conor
FUDForum. Page generated in 0.02837 seconds
