Re: Data Set Cache if Data Set is used twice [message #368500 is a reply to message #368496] |
Thu, 04 June 2009 15:16 |
Originally posted by: jasonweathersby.windstream.net
Mark,
What version of BIRT are you using. In 2.3.2 this should only be called
once. Another thing to try is to bind the first report item to the
dataset and the then the other two to the first report item.
Jason
Mark Mescher wrote:
> Hello,
> I have a report which contains 1 Table and 2 Charts. All are using the
> same Scripted Data Set (developed in Java). Birt is calling the
> fetch-Method of the dataset for all 3 items. I thought Birt would cache
> the first fetch-Call, this would increase performance... I've integrated
> the Reportengine in my Application (Servlet). Is there a possibility to
> enable caching for my report?
> Thx in advance!
> Mark
FUDForum. Page generated in 0.04078 seconds
