Home » Archived » BIRT » BIRT 2.3.2 - JNDI error: NameNotFoundException
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368374 is a reply to message #368365] |
Tue, 26 May 2009 15:28 |
Originally posted by: jasonweathersby.windstream.net
John,
Can you try
java:/db1
Jason
John wrote:
> I've a BIRT 2.2.1 report, which uses "JNDI URL=java:/comp/env/jdbc/db1".
> This works fine in my appserver.
> Now I changed th BIRT runtime to BIRT 2.3.2 and I get following error:
> [exec] 26.05.2009 14:24:10
> org.eclipse.birt.report.data.oda.jdbc.JndiDataSource getConnection
> [exec] INFO: javax.naming.NameNotFoundException: Name comp is not
> bound in this Context
> What is wrong??
> I also opened the report in 2.3.2 and saved it in 2.3.2 format - no
> changes!
> I also tried "java:/jdbc/db1" - no changes!
> I also tried "/jdbc/db1" - no changes!
> I use "java:/comp/env/jdbc/db1" everywhere in my app (in servlets and so
> on) and it works - so the JNDI entry exists and DB-Connection is correct.
> Any ideas??
> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368394 is a reply to message #368382] |
Wed, 27 May 2009 16:51 |
John,
What exception did you get with it?
Jason
John wrote:
> java:/db1 also doen't work
> John
> Jason Weathersby schrieb:
>> John,
>> Can you try
>> java:/db1
>> Jason
>>> URL=java:/comp/env/jdbc/db1". This works fine in my appserver.
>>> What is wrong??
>>> changes!
>>> so on) and it works - so the JNDI entry exists and DB-Connection is
>>> correct.
>>> Any ideas??
>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368395 is a reply to message #368394] |
Wed, 27 May 2009 16:52 |
Also what app server are you using?
Jason Weathersby wrote:
> John,
> Jason
>> John
>>> John,
>>> Can you try
>>> java:/db1
>>> Jason
>>>> not bound in this Context
>>>> What is wrong??
>>>> changes!
>>>> and so on) and it works - so the JNDI entry exists and DB-Connection
>>>> is correct.
>>>> Any ideas??
>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368423 is a reply to message #368414] |
Thu, 28 May 2009 15:22 |
John,
What I do not understand is that the error
Name comp is not bound in this Context
is complaining about comp, which the name I asked you to try did not
have in it.
Jason
John wrote:
> Error:
> [exec] INFO: javax.naming.NameNotFoundException: Name comp is not bound
> in this Context
> Server is tomcat 5.5.27
> As stated before: Report works fine with BIRT runtime 2.2.1?!
> Now I made a tiny new report (simple Datasource/set and 1 table) with
> BIRT 2.3.2, and I've the same problem :-(
>>> John,
>>> Jason
>>>> John
>>>>> John,
>>>>> Can you try
>>>>> java:/db1
>>>>> Jason
>>>>>> error:
>>>>>> What is wrong??
>>>>>> no changes!
>>>>>> Any ideas??
>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368445 is a reply to message #368431] |
Fri, 29 May 2009 15:50 |
John,
I just setup my webviewer application as described here
http://wiki.eclipse.org/BIRT/FAQ/Deployment#Q:_How_do_I_setu p_BIRT_to_use_Tomcat_Connection_Pooling
The only difference I made was that I put the context.xml in the
tomcat-5.5.20\conf directory. I used the url in the wiki and everything
worked fine. I changed the username just to verify that the connection
pool was working.
Jason
John wrote:
> If I use JNDI Url=java:/comp/env/jdbc/db1
> I get
> [exec] 28.05.2009 20:59:20
> If I use JNDI Url=java:/jdbc/db1
> I get
> [exec] 28.05.2009 21:04:20
> [exec] INFO: javax.naming.NameNotFoundException: Name db1 is not
> If I use JNDI Url=/jdbc/db1
> I get
> [exec] 28.05.2009 21:05:37
> [exec] INFO: javax.naming.NameNotFoundException: Name jdbc is not
> If I use JNDI Url=java:/db1
> I get
> [exec] 28.05.2009 21:01:38
> Does 'java:/db1' make any sense? Because the resource is defined as
> "jdbc/db1"? Does BIRT guess "jdbc"?
> Whats the difference between BIRT 2.2.1 and 2.3.2 and JNDI handling? (As
> I stated before in 2.2.1 it works. I'm impatient of BIRT upgrades there
> are always so a lot of new bugs (besides the old ones). We are using
> BIRT for about three years. Always hoping having a stable less buggy
> product after an upgrade. But there are so much bugs and a lot of tiny
> inconviences at design time that makes reporting a hell. We are really
> considering putting three years work to garbage.
>> John,
>> have in it.
>> Jason
>> John wrote:
>>> Error:
>>>>> John,
>>>>> Jason
>>>>>> John
>>>>>>> John,
>>>>>>> Can you try
>>>>>>> java:/db1
>>>>>>> Jason
>>>>>>>> error:
>>>>>>>> What is wrong??
>>>>>>>> no changes!
>>>>>>>> servlets and so on) and it works - so the JNDI entry exists and
>>>>>>>> Any ideas??
>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #368613 is a reply to message #368607] |
Mon, 15 June 2009 15:06 |
John,
If you post your code I will try it with a servlet, but it should not
matter. Could you deploy the webviewer as a test?
Jason
John wrote:
> I do not use the birt webviewer - I directly call runAndRender() from
> the BIRT API.
> As I mentioned before: It works perfectly with runtime 2.2.1 and if I
> change to runtime 2.3.2 I get the error...
>> John,
>> everything worked fine. I changed the username just to verify that
>> the connection pool was working.
>> Jason
>>> I get
>>> I get
>>> I get
>>> I get
>>> (As I stated before in 2.2.1 it works. I'm impatient of BIRT upgrades
>>> there are always so a lot of new bugs (besides the old ones). We are
>>> using BIRT for about three years. Always hoping having a stable less
>>> buggy product after an upgrade. But there are so much bugs and a lot
>>> of tiny inconviences at design time that makes reporting a hell. We
>>> are really considering putting three years work to garbage.
>>>> John,
>>>> have in it.
>>>> Jason
>>>> John wrote:
>>>>> Error:
>>>>> with BIRT 2.3.2, and I've the same problem :-(
>>>>>>> John,
>>>>>>> Jason
>>>>>>>> John
>>>>>>>>> John,
>>>>>>>>> Can you try
>>>>>>>>> java:/db1
>>>>>>>>> Jason
>>>>>>>>>> following error:
>>>>>>>>>> getConnection
>>>>>>>>>> What is wrong??
>>>>>>>>>> - no changes!
>>>>>>>>>> Any ideas??
>>>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #369052 is a reply to message #368613] |
Thu, 23 July 2009 09:20 |
John Missing name Messages: 513 Registered: July 2009 |
Maybe it's a classloader problem??
By debugging in the birts depth i saw "IConnectionFactory.PASS_IN_CONNECTION"!
So I do a jndi lookup in my code (instead of letting thios done by birt) and call
task.getAppContext().put(IConnectionFactory.PASS_IN_CONNECTI ON,sqlConnection);
before "runAndRender" - and now it works.
Is there somewhere an overview which appContext parameters exists???
There seems to be a lot of useful things by I never found any documentation!!
John
> John,
> Jason
>> the BIRT API.
>>> John,
>>> Jason
>>>> I get
>>>> I get
>>>> I get
>>>> I get
>>>> upgrades there are always so a lot of new bugs (besides the old
>>>> ones). We are using BIRT for about three years. Always hoping having
>>>> a stable less buggy product after an upgrade. But there are so much
>>>> bugs and a lot of tiny inconviences at design time that makes
>>>> reporting a hell. We are really considering putting three years work
>>>> to garbage.
>>>>> John,
>>>>> not have in it.
>>>>> Jason
>>>>> John wrote:
>>>>>> Error:
>>>>>>>> John,
>>>>>>>> Jason
>>>>>>>>> John
>>>>>>>>>> John,
>>>>>>>>>> Can you try
>>>>>>>>>> java:/db1
>>>>>>>>>> Jason
>>>>>>>>>>> following error:
>>>>>>>>>>> getConnection
>>>>>>>>>>> What is wrong??
>>>>>>>>>>> format - no changes!
>>>>>>>>>>> Any ideas??
>>>>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #369061 is a reply to message #369052] |
Thu, 23 July 2009 16:32 |
John,
Run this report in the designer /preview
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 Innovent Solutions,
Inc.</property>
<method name="beforeFactory"><![CDATA[// Create a hash table which
will contain lists of other lists
var topMap = new Packages.java.util.Hashtable();
// Request Attributes
var request = reportContext.getHttpServletRequest();
var requestAttrMap = new Packages.java.util.Hashtable();
var attrNames = request.getAttributeNames();
do {
var aName = attrNames.nextElement();
requestAttrMap.put(aName, request.getAttribute(aName).toString());
} while (attrNames.hasMoreElements())
topMap.put("requestAttributes", requestAttrMap);
// Request Parameters
var requestParamMap = new Packages.java.util.Hashtable();
var paramIter = request.getParameterMap().entrySet().iterator();
do{
var entry = paramIter.next();
requestParamMap.put(entry.getKey(), (entry.getValue()[0]));
} while (paramIter.hasNext())
topMap.put("requestParameters",requestParamMap);
// Session Attributes
var sessionAttrMap = new Packages.java.util.Hashtable();
var session = request.getSession();
// Insert a variable on the session
session.setAttribute("ReportAttribute", "arbitrary value to pass to
container");
var sessionAttrNames = session.getAttributeNames();
var i = 0;
do {
i ++;
var aaa = sessionAttrNames.nextElement();
sessionAttrMap.put(aaa, session.getAttribute(aaa));
} while (sessionAttrNames.hasMoreElements())
topMap.put("sessionAttributes", sessionAttrMap);
var ac = reportContext.getAppContext();
topMap.put("AppContextAttributes", ac);
// Get the system properties
topMap.put("systemProps", Packages.java.lang.System.getProperties());
// Store top map as a global
reportContext.setPersistentGlobalVariable("topMap", topMap);]]></method>
<data-sources>
<script-data-source name="setScript" id="4"/>
</data-sources>
<data-sets>
<script-data-set name="setEnvironmentVars" id="5">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">propName</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">propValue</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">propType</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">propName</property>
</structure>
<structure>
<property name="columnName">propValue</property>
</structure>
<structure>
<property name="columnName">propType</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">setScript</property>
<method name="open"><![CDATA[aMap =
reportContext.getPersistentGlobalVariable("topMap");
topIter = aMap.entrySet().iterator();
if (topIter == null)
topIterator = new Packages.java.util.Iterator();
//Packages.java.util.logging.Logger.getLogger("").info("OPEN NULL " );
innerIter = null;]]></method>
<method name="fetch"><![CDATA[do
{ // find an innerIter that has a new value
if (innerIter == null || innerIter.hasNext() == false)
{ // no value in the inner iterator, get the next Hashtable out of the
toHashtable
if (topIter.hasNext())
outerObject = topIter.next();
innerIter = outerObject.getValue().entrySet().iterator();
else
{ // no more top hash tables. close things up
return false;
while (innerIter.hasNext() == false)
// we must have another innerIter
innerObject = innerIter.next();
if( innerObject != null ){
row["propName"] = innerObject.getKey();
if( innerObject.getValue() != null ){
row["propValue"] = innerObject.getValue().toString();
}else{
row["propValue"] = "";
row["propType"] = outerObject.getKey();
}else{
row["propName"] = "";
row["propType"] = "";
return true;
Iterator i = topMap.entrySet().iterator();
while (i.hasNext()) {
Entry entry = (Entry) i.next();
logger.info(entry.getKey() + " " + entry.getValue() );
*/]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="detail" id="36">
<property name="backgroundColor">#FFFF80</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
</style>
<style name="headerfooter" id="37">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="38">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="orientation">landscape</property>
<property name="topMargin">0.5in</property>
<property name="leftMargin">0.5in</property>
<property name="bottomMargin">0.5in</property>
<property name="rightMargin">0.5in</property>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">setEnvironmentVars</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["propName"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propValue"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propType"]</expression>
<simple-property-list name="aggregateOn">
<value>propType</value>
</simple-property-list>
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="16"/>
<column id="17"/>
<header>
<row id="7">
<property name="style">headerfooter</property>
<cell id="8">
<label id="18">
<text-property
name="text">propName</text-property>
</label>
</cell>
<cell id="9">
<label id="20">
<text-property
name="text">propValue</text-property>
</label>
</cell>
</row>
</header>
<group id="22">
<property name="groupName">propType</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["propType"]</expression>
<structure name="toc">
<expression
name="expressionValue">row["propType"]</expression>
</structure>
<header>
<row id="23">
<cell id="24">
<data id="29">
<property
name="resultSetColumn">propType</property>
</data>
</cell>
<cell id="25"/>
</row>
<row id="33">
<property name="height">2pt</property>
<property name="backgroundColor">#000000</property>
<cell id="34"/>
<cell id="35"/>
</row>
</header>
<footer>
<row id="26">
<cell id="27"/>
<cell id="28"/>
</row>
</footer>
</group>
<detail>
<row id="10">
<property name="style">groupheader</property>
<cell id="11">
<data id="19">
<property
name="resultSetColumn">propName</property>
</data>
</cell>
<cell id="12">
<data id="21">
<property
name="resultSetColumn">propValue</property>
</data>
</cell>
</row>
<row id="30">
<property name="backgroundColor">#C0C0C0</property>
<cell id="31"/>
<cell id="32"/>
</row>
</detail>
<footer>
<row id="13">
<cell id="14"/>
<cell id="15"/>
</row>
</footer>
</table>
</body>
</report>
> and call
> documentation!!
> John
>> John,
>> Jason
>>> the BIRT API.
>>>> John,
>>>> Jason
>>>>> I get
>>>>> I get
>>>>> I get
>>>>> I get
>>>>> handling? (As I stated before in 2.2.1 it works. I'm impatient of
>>>>> BIRT upgrades there are always so a lot of new bugs (besides the
>>>>> old ones). We are using BIRT for about three years. Always hoping
>>>>> having a stable less buggy product after an upgrade. But there are
>>>>> so much bugs and a lot of tiny inconviences at design time that
>>>>> makes reporting a hell. We are really considering putting three
>>>>>> John,
>>>>>> not have in it.
>>>>>> Jason
>>>>>> John wrote:
>>>>>>> Error:
>>>>>>>>> John,
>>>>>>>>> Jason
>>>>>>>>>> John
>>>>>>>>>>> John,
>>>>>>>>>>> Can you try
>>>>>>>>>>> java:/db1
>>>>>>>>>>> Jason
>>>>>>>>>>>> following error:
>>>>>>>>>>>> getConnection
>>>>>>>>>>>> What is wrong??
>>>>>>>>>>>> Any ideas??
>>>>>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #369066 is a reply to message #369061] |
Fri, 24 July 2009 08:04 |
Thanks Jason for the report it works great - but optional prameters like PASS_IN_CONNECTION and so on aren't shown. And
while debugging in ODA I saw there's a parameter for switching classloader... - So what I meant is, that there's a lack
of documentation for all/most or even 'important' parameters. Ok, everybody can debug BIRTs source and can obtain which
parameters are queried - but are these parameters a public?
TJX,
John
> John,
> Jason
>> birt) and call
>> documentation!!
>> John
>>> John,
>>> Jason
>>>> from the BIRT API.
>>>> I change to runtime 2.3.2 I get the error...
>>>>> John,
>>>>> Jason
>>>>>> I get
>>>>>> I get
>>>>>> I get
>>>>>> I get
>>>>>> as "jdbc/db1"? Does BIRT guess "jdbc"?
>>>>>>> John,
>>>>>>> not have in it.
>>>>>>> Jason
>>>>>>> John wrote:
>>>>>>>> Error:
>>>>>>>>>> John,
>>>>>>>>>> Jason
>>>>>>>>>>> John
>>>>>>>>>>>> John,
>>>>>>>>>>>> Can you try
>>>>>>>>>>>> java:/db1
>>>>>>>>>>>> Jason
>>>>>>>>>>>>> following error:
>>>>>>>>>>>>> getConnection
>>>>>>>>>>>>> What is wrong??
>>>>>>>>>>>>> Any ideas??
>>>>>>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #369081 is a reply to message #369066] |
Mon, 27 July 2009 17:43 |
John,
You are correct. We need to document this on the wiki or the website.
Can you open a bugzilla entry for this?
Jason
> PASS_IN_CONNECTION and so on aren't shown. And while debugging in ODA I
> is, that there's a lack of documentation for all/most or even
> obtain which parameters are queried - but are these parameters a public?
> TJX,
> John
>> John,
>> Jason
>>> birt) and call
>>> documentation!!
>>> John
>>>> John,
>>>> not matter. Could you deploy the webviewer as a test?
>>>> Jason
>>>>> from the BIRT API.
>>>>>> John,
>>>>>> that the connection pool was working.
>>>>>> Jason
>>>>>>> I get
>>>>>>> I get
>>>>>>> I get
>>>>>>> I get
>>>>>>> are so much bugs and a lot of tiny inconviences at design time
>>>>>>> that makes reporting a hell. We are really considering putting
>>>>>>>> John,
>>>>>>>> not have in it.
>>>>>>>> Jason
>>>>>>>> John wrote:
>>>>>>>>> Error:
>>>>>>>>> table) with BIRT 2.3.2, and I've the same problem :-(
>>>>>>>>>>> John,
>>>>>>>>>>> Jason
>>>>>>>>>>>> John
>>>>>>>>>>>>> John,
>>>>>>>>>>>>> Can you try
>>>>>>>>>>>>> java:/db1
>>>>>>>>>>>>> Jason
>>>>>>>>>>>>>> appserver.
>>>>>>>>>>>>>> following error:
>>>>>>>>>>>>>> getConnection
>>>>>>>>>>>>>> What is wrong??
>>>>>>>>>>>>>> Any ideas??
>>>>>>>>>>>>>> THX!
Re: BIRT 2.3.2 - JNDI error: NameNotFoundException [message #404640 is a reply to message #369081] |
Thu, 30 July 2009 05:58 |
bugzilla entry opened
John
> John,
> Jason
>> like PASS_IN_CONNECTION and so on aren't shown. And while debugging in
>> meant is, that there's a lack of documentation for all/most or even
>> TJX,
>> John
>>> John,
>>> Jason
>>>> birt) and call
>>>> documentation!!
>>>> John
>>>>> John,
>>>>> Jason
>>>>>> from the BIRT API.
>>>>>> if I change to runtime 2.3.2 I get the error...
>>>>>>> John,
>>>>>>> Jason
>>>>>>>> I get
>>>>>>>> I get
>>>>>>>> I get
>>>>>>>> I get
>>>>>>>> of BIRT upgrades there are always so a lot of new bugs (besides
>>>>>>>> the old ones). We are using BIRT for about three years. Always
>>>>>>>> hoping having a stable less buggy product after an upgrade. But
>>>>>>>> there are so much bugs and a lot of tiny inconviences at design
>>>>>>>> time that makes reporting a hell. We are really considering
>>>>>>>>> John,
>>>>>>>>> did not have in it.
>>>>>>>>> Jason
>>>>>>>>> John wrote:
>>>>>>>>>> Error:
>>>>>>>>>> getConnection
>>>>>>>>>>>> John,
>>>>>>>>>>>> Jason
>>>>>>>>>>>>> John
>>>>>>>>>>>>>> John,
>>>>>>>>>>>>>> Can you try
>>>>>>>>>>>>>> java:/db1
>>>>>>>>>>>>>> Jason
>>>>>>>>>>>>>>> appserver.
>>>>>>>>>>>>>>> following error:
>>>>>>>>>>>>>>> getConnection
>>>>>>>>>>>>>>> What is wrong??
>>>>>>>>>>>>>>> Any ideas??
>>>>>>>>>>>>>>> THX!
Current Time: Fri Apr 26 22:28:57 GMT 2024
Powered by FUDForum. Page generated in 0.05008 seconds
