Re: Format Number on Table [message #368372 is a reply to message #368357] |
Tue, 26 May 2009 15:17 |
Originally posted by: jasonweathersby.windstream.net
Tero,
You can also modify the expression for the actual value like:
dataSetRow["mypercentvalue"]/100
Jason
Tero wrote:
> Hello All,
> While trying to format a number in a table to "Percent", I see a strange
> behaviour:
> Having to display a float, even the preview is displaying for 1,234.56:
> 123456.00% if I select 2 Decimal places!
> Souldn't that be something like 1,234.56% ? That is what I would like to
> have. A solution would be to format it "fixed" and add the "%" manually,
> but that's a workaround...
> Tero
Re: Format Number on Table [message #368422 is a reply to message #368415] |
Thu, 28 May 2009 15:20 |
Tero,
Did you log a bug for this?
Jason
tero wrote:
> Hello Jason,
> Thanks for your answer.
> That would be a workaround too. Is the "Percent" format not meant to
> deal with float?
> What if in a future Birt release, it displays the correct way?
> Is there a reason why the number 1,234.56 is displayed 123456.00% when
> formatted as "Percent" ?
> Tero
FUDForum. Page generated in 1.04163 seconds
