Home » Language IDEs » AspectJ » Cannot create an aspect in Eclipse
Cannot create an aspect in Eclipse [message #37618] Thu, 24 June 2004 07:40 Go to next message
Originally posted by: fintan.conway.esb.ie
Hi All,
I have downloaded the aspect12.jar and manually installed in Eclipse 3.0
RC2.
I am trying to follow the help that was installed, but I cannot add an
aspect. I have created the AspectJ project, but when I try File -> New ->
Aspect, there is NO option for Aspect.
What can I do?
Many thanks for your help,
Fintan
Re: Cannot create an aspect in Eclipse [message #37645 is a reply to message #37618] Thu, 24 June 2004 08:20 Go to previous messageGo to next message
Hi Fintan,
To the best of my knowledge there is no version yet of AJDT that will
work in RC2. According to the AJDT download page
( http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/org. eclipse.ajdt/download.html)
the most recent release of AJDT, 1.1.10, only works up to Eclipse 3.0
M9. Unless you absolutely must work on the latest Eclipse RC then that
is what I would recommend.
AJDT 1.1.11, which will work on Eclipse RC3, is due out any day now...
George
Fintan wrote:
> Hi All,
> RC2.
> What can I do?
> Fintan
Re: Cannot create an aspect in Eclipse [message #37683 is a reply to message #37645] Thu, 24 June 2004 09:47 Go to previous messageGo to next message
Hi again,
Update on my previous note. I've double checked and apparently AJDT
1.1.10 *should* work alright on Eclipse 3.0. That'll teach me to post in
haste.
So, returning back to your original post Fintan, can you confirm that it
was AJDT 1.1.10 that you were using. You refer to "aspect12.jar" and I
am not terribly sure what that means...
George
George Harley wrote:
> Hi Fintan,
> Best regards,
> George
> Fintan wrote:
>> Hi All,
>> RC2.
>> New ->
>> What can I do?
>> Fintan
Re: Cannot create an aspect in Eclipse [message #37771 is a reply to message #37683] Tue, 29 June 2004 20:21 Go to previous messageGo to next message
Hi George and Fintan,
I´m having a problem with AJDT and Eclipse v3 RC 3 also. I have
downloaded usint the "Help / Software Update" option.
It appears to be installed fine. It appears on the "About Box", and the
"AspectJ Project" is on the "File / New / Project", but when I select it
and click next, I receive a error:
"The selected wizard could not be started. Reason: Plug-in
org.eclipse.ajdt.ui was unable to load class
org.eclipse.ajdt.internal.ui.wizards.AspectJProjectWizard"
On my plugins folder I have "org.eclipse.ajdt.ui_0.6.4" and
"org.eclipse.aspectj_1.1.4".
Any ideas?
Thanks in advance
Alessandro
> Hi again,
> haste.
> Best regards,
> George
>> Hi Fintan,
>> Best regards,
>> George
>> Fintan wrote:
>>> Hi All,
>>> RC2.
>>> New ->
>>> What can I do?
>>> Fintan
Re: Cannot create an aspect in Eclipse [message #37804 is a reply to message #37771] Wed, 30 June 2004 06:14 Go to previous message
Hi Alessandro,
It sounds to me like you *might* have the wrong version of AJDT
installed in your Eclipse 3.0. If you have installed AJDT 1.1.10 then in
your plugins folder you should be seeing "org.eclipse.ajdt.ui_0.6.10"
and "org.eclipse.aspectj_1.1.10" rather than the entries you list in
your note. Please can you confirm the update site URL that you used when
installing. For AJDT 1.1.10 it should be
http://download.eclipse.org/technology/ajdt/30M8/update
The list of all AJDT update site URLs is given in the project download
page here
George
> Any ideas?
> Thanks in advance
> Alessandro
>> Hi again,
>> in haste.
>> it was AJDT 1.1.10 that you were using. You refer to "aspect12.jar"
>> and I am not terribly sure what that means...
>> Best regards,
>> George
>>> Hi Fintan,
>>> that is what I would recommend.
>>> Best regards,
>>> George
>>> Fintan wrote:
>>>> Hi All,
>>>> 3.0
>>>> RC2.
>>>> New ->
>>>> What can I do?
>>>> Fintan
Re: Cannot create an aspect in Eclipse [message #580912 is a reply to message #37618] Thu, 24 June 2004 08:20 Go to previous message
Hi Fintan,
George
Fintan wrote:
> Hi All,
> RC2.
> What can I do?
> Fintan
Re: Cannot create an aspect in Eclipse [message #580927 is a reply to message #37645] Thu, 24 June 2004 09:47 Go to previous message
Hi again,
haste.
George
> Hi Fintan,
> Best regards,
> George
> Fintan wrote:
>> Hi All,
>> RC2.
>> New ->
>> What can I do?
>> Fintan
Re: Cannot create an aspect in Eclipse [message #581004 is a reply to message #37683] Tue, 29 June 2004 20:21 Go to previous message
Any ideas?
Thanks in advance
Alessandro
> Hi again,
> haste.
> Best regards,
> George
>> Hi Fintan,
>> Best regards,
>> George
>> Fintan wrote:
>>> Hi All,
>>> RC2.
>>> New ->
>>> What can I do?
>>> Fintan
Re: Cannot create an aspect in Eclipse [message #581026 is a reply to message #37771] Wed, 30 June 2004 06:14 Go to previous message
Hi Alessandro,
page here
George
> Any ideas?
> Thanks in advance
> Alessandro
>> Hi again,
>> in haste.
>> Best regards,
>> George
>>> Hi Fintan,
>>> Best regards,
>>> George
>>> Fintan wrote:
>>>> Hi All,
>>>> 3.0
>>>> RC2.
>>>> New ->
>>>> What can I do?
>>>> Fintan
Previous Topic:Anyone at Java One?
Next Topic:AJDT 1.1.10 Samples problem with Eclipse 3.0
Current Time: Fri Jul 18 05:22:03 EDT 2025
Powered by FUDForum. Page generated in 0.11022 seconds
