Re: java.lang.StackOverflowError [message #368320 is a reply to message #368312] |
Wed, 20 May 2009 17:49 |
Mark,
Are you using 2.3.0? I saw one bug in bugzilla for stack overflow but I
do not believe it is the same issue you have. Can you open a bug and
attach your report to it?
Jason
Mark wrote:
> Hello,
> While I modified my BIRT 2.3 report, It closed itself. I got a message
> asked me to check the .log file when I tried to open it again.
> I copied part of the log file below. Pls let me know if anyone know how
> to fix it to be able to open the BIRT designer. Thanks.
> !SESSION 2009-05-20 12:53:50.318
> eclipse.buildId=I20080617-2000
> java.version=1.6.0_02
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.osgi 4 0 2009-05-20 12:53:56.162
> !MESSAGE Application error
> !STACK 1
> at java.util.Collections$UnmodifiableCollection.contains(Unknow n
> Source)
> at
> org.eclipse.birt.report.model.elements.strategy.ReportItemPr opSearchStrategy.getPropertyFromSelf(ReportItemPropSearchStr ategy.java:141)
> at
> org.eclipse.birt.report.model.core.PropertySearchStrategy.ge tNonIntrinsicPropertyFromElement(PropertySearchStrategy.java :183)
> at
> org.eclipse.birt.report.model.core.PropertySearchStrategy.ge tPropertyExceptRomDefault(PropertySearchStrategy.java:89)
> at
> org.eclipse.birt.report.model.core.DesignElement.getProperty (DesignElement.java:935)
> at
> org.eclipse.birt.report.model.elements.ReportItem.getPropert y(ReportItem.java:163)
> at
> org.eclipse.birt.report.model.api.ComplexValueHandle.getValu e(ComplexValueHandle.java:121)
> at
> org.eclipse.birt.report.model.api.DimensionHandle.getUnits(D imensionHandle.java:170)
> at
> org.eclipse.birt.report.designer.core.model.ReportItemtHandl eAdapter.getLocation(ReportItemtHandleAdapter.java:55)
> at
> org.eclipse.birt.report.designer.core.model.ReportItemtHandl eAdapter.getbounds(ReportItemtHandleAdapter.java:158)
> at
> org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.editparts.ReportElementEditPart.getBounds(ReportElementEd itPart.java:411)
> at
> org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.editparts.TableEditPart.getPreferredSize(TableEditPart.ja va:1042)
> at
> org.eclipse.birt.report.designer.core.model.DesignElementHan dleAdapter.getDefaultSize(DesignElementHandleAdapter.java:14 8)
> at
> org.eclipse.birt.report.designer.core.model.schematic.TableH andleAdapter.getDefaultWidth(TableHandleAdapter.java:700)
> at
> org.eclipse.birt.report.designer.core.model.schematic.Column HandleAdapter.getWidth(ColumnHandleAdapter.java:100)
> at
> org.eclipse.birt.report.designer.core.model.schematic.TableH andleAdapter.getDefaultWidth(TableHandleAdapter.java:726)
Re: java.lang.StackOverflowError [message #368332 is a reply to message #368325] |
Thu, 21 May 2009 15:42 |
Sure. I have at least 8 different versions on my mahcine.
Mark wrote:
> Hi Jason,
> I installed BIRT 2.3.2 in another directory and open that report without
> any problem. Can I keep both version of BIRT on my computer without
> running into any problem?
> thanks.
> M
FUDForum. Page generated in 0.04514 seconds
