How to access type definitions from XSD namespace as part of ResourceSet? [message #37614] |
Mon, 01 March 2004 12:55  |
Originally posted by: hoe.zurich.ibm.com
I'm trying to read from an XSD file into a ResourceSet. The contained
type definitions reference simple types from the xsd namespace
(http://www.w3.org/2001/XMLSchema). I end up with a ResourceSet that
contains one resource (not two, as I had expected).
Do I have to do anything special to get defintions from the cached
xml.xsd included in the ResourceSet; or what's the other/preferred way
to get hold of them? Because of the way the ResourceSet is currently
made up, looping over all XSDSchema.getTypeDefinitions() for all
contained Resources won't do the trick for finding e.g. the
XSDTypeDefiniton for "xsd:string". Where/how can I find that definition
instead?
Here's a shortcut version of what I'm doing:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResource(createURI(uri), true);
and here's a shortcut version of my XSD file:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ns="http://www.whathaveyou.com">
<!-- etc. -->
</xsd:schema>
Christian
Re: How to access type definitions from XSD namespace as part of ResourceSet? [message #37639 is a reply to message #37614] |
Mon, 01 March 2004 13:59  |
Christian,
Given an XSDSchema x, calling x.getSchemaForSchema() will get the you the
schema for schemas; there is a single shared instance of this schema that's
used by all other schemas.
Christian Hoertnagl wrote:
> instead?
> <!-- etc. -->
> </xsd:schema>
> Christian
Re: How to access type definitions from XSD namespace as part of ResourceSet? [message #583624 is a reply to message #37614] |
Christian,
> instead?
> <!-- etc. -->
> </xsd:schema>
> Christian
FUDForum. Page generated in 0.04049 seconds
