Necessary to write to disk when exporting (BIRT Engine application)?? [message #368184] |
Fri, 08 May 2009 19:28 |
Originally posted by: asd.asd.com
I use this code when I export to eg. word;
IReportRunnable design;
try {
design = reportEngine.openReportDesign(reportContent);
// Create task to run the report - use the task to execute and run the
report,
IRunTask task = reportEngine.createRunTask(design);
// Write a rptdocument to the specified destination based on the above
design.
task.run(reportPath);
// Open the created rptdocument.
IReportDocument reportDocument =
reportEngine.openReportDocument(reportPath);
After reading a ReportDesignHandle an IRunTask is created. When 'run' is
executed on this task a .rptdocument is stored in the 'reportPath'. Next the
..rptdocument file (just written to disk) is read back into a IRportDocument.
Is it possible to avoid writing the .rptdocument file to disk and load it
directly into the IReportDocument object?
Re: Necessary to write to disk when exporting (BIRT Engine application)?? [message #368198 is a reply to message #368184] |
Mon, 11 May 2009 14:53 |
Can you not just use a runandrender task?
> try {
> report,
> design.
> the .rptdocument file (just written to disk) is read back into a
> IRportDocument.
> it directly into the IReportDocument object?
FUDForum. Page generated in 0.02939 seconds
