Home » Archived » BIRT » convert ArrayList to table in DEAPI
Re: convert ArrayList to table in DEAPI [message #368177 is a reply to message #368172] |
Fri, 08 May 2009 14:32 |
Conor,
If you already have the data why not use a grid and insert labels or
text fields that you can paste the data into?
Jason
Conor O'Mahony wrote:
> I have a list of lists of strings, which corresponds to data that I want
> to insert into a Table using the Design Engine API.
> ArrayList<List<String>> tableParameters;
> I have created a table as follows -
> TableHandle table = factory.newTableItem( null,
> tableParameters.get(0).size());
> table.setWidth( "100%" );
> table.setRepeatHeader(true);
> The first list of strings in the tableParameters list correspond to the
> table headings, so I can add the table heading to the created table from
> this.
> List<String> headings = parameters.get(0);
> // table header
> RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
> LabelHandle label;
> int i = 0;
> for( String item : headings)
> label= factory.newLabel( null );
> label.setText(item);
> CellHandle cell = (CellHandle) tableheader.getCells( ).get( i );
> cell.getContent( ).add( label);
> i++;
> However I am not sure what is the best way to fill the table detail.
> Should I try and create a dataset/datasource or is there a way of
> iterating over each table detail row directly and filling it with the
> list data?
Re: convert ArrayList to table in DEAPI [message #368183 is a reply to message #368181] |
Fri, 08 May 2009 17:22 |
Conor,
I do not think so. If you have to use a table it is best that you add a
dataset then create the binding on the table and fill out the detail
row. If you need some sample de api code to do this let me know.
Jason
> Hi Jason,
> I did think of that but thought a table would be better as the data may
> contain a large number of lines and I wanted to use setRepeatHeader() to
> repeat the headers on the top of each page... is there a way to do that
> with a grid?
> Many thanks,
> Conor
> Jason Weathersby wrote:
>> Conor,
>> Jason
>>> Hi,
>>> want to insert into a Table using the Design Engine API.
>>> the table headings, so I can add the table heading to the created
>>> table from this.
>>> // table header
>>> LabelHandle label;
>>> int i = 0;
>>> i );
>>> i++;
>>> list data?
Re: convert ArrayList to table in DEAPI [message #368188 is a reply to message #368183] |
Mon, 11 May 2009 08:55 |
Conor O'Mahony Messages: 108 Registered: July 2009 |
Hi Jason,
Thanks for your reply. I have seen some sample deapi code for creating dataset and tables (e.g.
http://wiki.eclipse.org/Java_-_Build_Dynamic_Table_(BIRT) ) but if you could point me to some code
that might be more suitable when I already have the data in an array then that would be great.
Many thanks,
Conor
> Conor,
> Jason
>> Hi Jason,
>> may contain a large number of lines and I wanted to use
>> setRepeatHeader() to repeat the headers on the top of each page... is
>> there a way to do that with a grid?
>> Many thanks,
>> Conor
>>> Conor,
>>> Jason
>>>> Hi,
>>>> table from this.
>>>> // table header
>>>> LabelHandle label;
>>>> int i = 0;
>>>> i );
>>>> i++;
>>>> the list data?
Re: convert ArrayList to table in DEAPI [message #368194 is a reply to message #368188] |
Mon, 11 May 2009 14:44 |
Conor,
Here is an example of doing a scripted data set within a report. You
will need to modify it to use your object.
Jason
package DEAPI;
import java.io.File;
import java.io.IOException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.DesignEngine;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.StyleHandle;
import org.eclipse.birt.report.model.api.TableGroupHandle;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.ColumnHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import org.eclipse.birt.report.model.api.metadata.IMetaDataDictiona ry;
import org.eclipse.birt.report.model.elements.interfaces.IReportIte mModel;
import org.eclipse.birt.report.model.elements.interfaces.IStyleMode l;
import org.eclipse.birt.report.model.api.ScriptDataSetHandle;
import org.eclipse.birt.report.model.api.ScriptDataSourceHandle;
import com.ibm.icu.util.ULocale;
import
org.eclipse.birt.report.model.api.elements.structures.Result SetColumn;
import java.util.Iterator;
import java.util.List;
import org.eclipse.birt.report.model.api.DataSetHandle;
public class ScriptedDS
ReportDesignHandle reportDesignHandle = null;
ElementFactory elementFactory = null;
IMetaDataDictionary dict = null;
ComputedColumn cs1, cs2, cs3, cs4, cs5 = null;
public static void main( String[] args ) throws SemanticException,
IOException
new ScriptedDS( ).createReport( );
void createReport( ) throws SemanticException, IOException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_3_2/birt-runtime-2_3_2/ReportEngine ");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
// Create a new report
reportDesignHandle = session.createDesign( );
// Element factory is used to create instances of BIRT elements.
elementFactory = reportDesignHandle.getElementFactory( );
dict = new DesignEngine( null ).getMetaData( );
createMasterPages( );
createDataSources( );
createDataSets( );
createBody( );
reportDesignHandle.saveAs("output/desample/SDS.rptdesign"
);//$NON-NLS-1$//$NON-NLS-2$
reportDesignHandle.close();
System.out.println("finished");
Platform.shutdown();
//Scripted Data Set
private void createDataSources( ) throws SemanticException
ScriptDataSourceHandle dataSourceHandle =
elementFactory.newScriptDataSource( "Data Source" );
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
private void createDataSets( ) throws SemanticException
ScriptDataSetHandle dataSetHandle = elementFactory.newScriptDataSet(
"Data Set" );//$NON-NLS-1$
dataSetHandle.setDataSource( "Data Source" );//$NON-NLS-1$
// Set open( ) in code
dataSetHandle.setOpen( "i=0;"
// Set fetch( ) in code
dataSetHandle.setFetch( "if ( i < 20 ){"
+ "row[\"Month\"] = 1;"
+ "row[\"Product\"] = 'My Product' + parseInt(i/3);"
+ "row[\"Amount\"] = i;"
+ "i++;"
+ "return true;}" + "else return false;" );
PropertyHandle computedSet =
dataSetHandle.getPropertyHandle(ScriptDataSetHandle.RESULT_S ET_PROP);
// Since this is a Scripted Data Source you need to tell the
// DataSet what the columns are. For this example, we will just
// hard code the known resultColumn values
ResultSetColumn resultColumn = StructureFactory.createResultSetColumn();
resultColumn.setPosition(1);
resultColumn.setColumnName("Month");
resultColumn.setDataType("integer");
computedSet.addItem(resultColumn);
resultColumn.setPosition(2);
resultColumn.setColumnName("Product");
resultColumn.setDataType("string");
resultColumn.setPosition(3);
resultColumn.setColumnName("Amount");
reportDesignHandle.getDataSets( ).add( dataSetHandle );
private void createMasterPages( ) throws ContentException, NameException
DesignElementHandle simpleMasterPage =
elementFactory.newSimpleMasterPage( "Master Page" );//$NON-NLS-1$
reportDesignHandle.getMasterPages( ).add( simpleMasterPage );
private void createBody( ) throws SemanticException
TableHandle table = elementFactory.newTableItem( null, 3, 1, 1, 1 );
table.setProperty( IStyleModel.TEXT_ALIGN_PROP,
DesignChoiceConstants.TEXT_ALIGN_CENTER );
table.setWidth( "80%" );//$NON-NLS-1$
table.setProperty( IReportItemModel.DATA_SET_PROP, "Data Set"
);//$NON-NLS-1$
ColumnHandle ch = (ColumnHandle)table.getColumns().get(0);
//ch.setProperty("Width", "3in");
ch.getWidth().setStringValue("3in");
// bind the data set columns to the table
DataSetHandle dataSetHandle = (DataSetHandle)
reportDesignHandle.getDataSets().get(0);
List resultSetCols =
dataSetHandle.getListProperty(DataSetHandle.RESULT_SET_PROP) ;
PropertyHandle boundCols = table.getColumnBindings();
for (Iterator iterator = resultSetCols.iterator(); iterator.hasNext();) {
ResultSetColumn rsHandle = (ResultSetColumn) iterator.next();
ComputedColumn col = StructureFactory.createComputedColumn();
col.setName(rsHandle.getColumnName());
col.setExpression("dataSetRow[\"" + rsHandle.getColumnName() + "\"]");
boundCols.addItem(col);
// Header
RowHandle header = (RowHandle) table.getHeader( ).get( 0 );
CellHandle tcell = (CellHandle) header.getCells( ).get( 0 );
tcell.getWidth().setStringValue("3in");
LabelHandle label = elementFactory.newLabel( null );
label.setText( "Order" );//$NON-NLS-1$
tcell.getContent( ).add( label );
tcell = (CellHandle) header.getCells( ).get( 1 );
label.setText( "Product" );//$NON-NLS-1$
tcell = (CellHandle) header.getCells( ).get( 2 );
label.setText( "Amount" );//$NON-NLS-1$
RowHandle detail = (RowHandle) table.getDetail( ).get( 0 );
DataItemHandle data = elementFactory.newDataItem( null );
tcell = (CellHandle) detail.getCells( ).get( 1 );
data.setResultSetColumn("Product");
tcell.getContent( ).add( data );
tcell = (CellHandle) detail.getCells( ).get( 2 );
data.setResultSetColumn( "Amount" );
reportDesignHandle.getBody( ).add( table );
> Hi Jason,
> could point me to some code that might be more suitable when I already
> Many thanks,
> Conor
>> Conor,
>> a dataset then create the binding on the table and fill out the detail
>> Jason
>>> Hi Jason,
>>> Many thanks,
>>> Conor
>>>> Conor,
>>>> Jason
>>>>> Hi,
>>>>> table from this.
>>>>> // table header
>>>>> LabelHandle label;
>>>>> int i = 0;
>>>>> ).get( i );
>>>>> i++;
>>>>> detail. Should I try and create a dataset/datasource or is there a
>>>>> way of iterating over each table detail row directly and filling it
>>>>> with the list data?
Current Time: Fri Apr 26 19:35:19 GMT 2024
Powered by FUDForum. Page generated in 0.03432 seconds
