Re: Birt Batch Job [message #368164 is a reply to message #368161] |
Thu, 07 May 2009 19:16 |
Kishore,
Take a look at the servlet example
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
In the comments is a 2.2 example which should work fine with 2.3+
Jason
kishore wrote:
> I am working on a scheduler that will run the birt reports in my web
> application. The scheduler will get birt design name, report parameters
> as the input parameters. Can any one please suggest me the best
> approach. I started with ReportRunner. But the call to the funciton
> Platform.startup(config) was throwing an exception. The code in the if
> block of the platform.java is getting executed. But my application is
> not a standalone application, its an web application. What might be
> reasons for this behaviour ?
> IPlatformContext context = config.getPlatformContext( );
> if( context == null )
> context = new PlatformFileContext( config );
> config.setProperty( PlatformConfig.PLATFORM_CONTEXT,
> context );
> Thanks & Regards,
> Kishore.
Re: Birt Batch Job [message #368167 is a reply to message #368165] |
Thu, 07 May 2009 20:31 |
Understood, but If you want to package the birt runtime in a webapp it
is probably better to use the plaformservletcontext. If you do not want
to do that reportrunner should be fine.
kishore wrote:
> Jason,
> Thanks for the reply. The servlet will not work here. My code should
> should be able to run the reports in the back end i.e. the ViewerServlet
> will not at all come into the picture. The code will should be able to
> run the report and save it in pdf format without rendering it to the user.
> Kishore.
Re: Birt Batch Job [message #368169 is a reply to message #368168] |
Thu, 07 May 2009 21:21 |
What are you setting BIRT_HOME to?
It has to be a hard directory if you are using the PlatformFileContext.
The directory must contain the birt plugins directory and a
configuration directory containing the config.ini. You can write your
own Platform Context or use the PlatformServletContext to do different
deployments.
Jason
kishore wrote:
> Jason,
> I am calling the ReportRunner as shown below.
> String platform = "//WebContent//WEB-INF//platform//";
> System.setProperty("BIRT_HOME",birtHome);
> // System.setProperty("BIRT_HOME"," "); ->> i tried this as mine is a
> //web application deployed as
> //a war.But did not work
> int result = new ReportRunner(args).execute();
> In execute method of ReportRunner the following call
> Platform.startup( config );
> to the following lines in the startup method executed.
> if( platform == null )
> if (config == null)
> config = new PlatformConfig();
> //I was getting Context as null . So the PlaformFileContext method is
> executed.
> Do you know why it is happening ?
> context );
> Kishore.
Re: Birt Batch Job [message #368176 is a reply to message #368175] |
Fri, 08 May 2009 14:29 |
Krishore
I am not sure what is happening here, But ideally what you want to do
is startup the platform only once when your application starts up. Get
the engine and for each new run just create an engine task to run and
render the report. I believe reportrunner is just a sample and starts
up the platform and then shuts it down. In a web app that is a bad idea.
Jason
kishore wrote:
> Jason,
> I am setting BIRT_HOME = \WEB-INF\platforms\. It is working now but for
> the first invocation of ReportRunner. For each invoction of the
> ReportRunner i have to restart my application server.If i try to run the
> ReportRunner for the second time i am getting an exception in the below
> code of the OSGILauncher class. During the second invocation of the
> ReportRunner the value of context is null, so context is assigned to an
> instance of PlatformFileContext.
> My code is as given below:
> some function(){
> System.setProperty("BIRT_HOME","\\WEB-INF\\platform\\");
> I am missing this statement that is found in the main method of the
> ReporRunner class System.exit(result).
> //Platform.class
> config.setProperty( PlatformConfig.PLATFORM_CONTEXT, context );
> //OSGILauncher.class
> platformConfig = config;
> if ( context == null )
> throw new BirtException(PluginId,PlatformContext is not setted - {0}",
> new Object[]{"PlatformConfig"} ); //$NON-NLS-1$
> String root = context.getPlatform( );
> platformDirectory = new File( root );
> if ( !platformDirectory.exists( ) || !platformDirectory.isDirectory( ) )
> throw new BirtException( PluginId,"Could not start the Framework - {0}"
> + root, root ); //$NON-NLS-1$
FUDForum. Page generated in 0.04287 seconds
