Hide/Show Report Parameters [message #368157] |
Thu, 07 May 2009 14:03 |
Originally posted by: heloneverett.alliance.biz
I want to be able to hide or show a report parameter based on the value
in a another report parameter that the user has selected.
Is there anyway to do this?
Thanks for any help.
Re: Hide/Show Report Parameters [message #369013 is a reply to message #369003] |
Sat, 18 July 2009 04:01 |
Originally posted by: johnw.innoventsolutions.com
Mario,
Either look into cascading parameters (populating one parameter based on
the results of another), or you might want to consider using an external
parameter dialog and just passing the parameters into the BIRT engine.
John
Mario Hochreiter wrote:
> Hallo Mitch
> I've the same requirement as Helon, but i don't understand your answer.
> I think you are mixing things. As far is i understand Helon and I want
> to show/hide a parameter based on another parameter.
> Your answer seems to show/hide a "Report Item" (like Label, Text ...)
> based on a parameter, or am i wrong?
> Would be great if someone could give a solution for hiding/showing a
> report parameter based on another report parameter.
> Mario
FUDForum. Page generated in 0.04196 seconds
