Sorting on Strings? [message #368121] |
Tue, 05 May 2009 14:09 |
Originally posted by: asddd.asd.com
I have an XML as data source where all attributes are Strings:
<data order="1">
<item id="box" value="4"/>
</data>
<data order="2">
<item id="circle" value="2"/>
</data>
<data order="10">
</data>
Now I would like to sort on the attribute 'order', but since 'order' is a
string the result is the following order:
1
10
2
instead of:
1
2
10
Are there any build in BIRT functions that converts a string to an integer
or is it only possible to get the correct order if I change my XML format?
Re: Sorting on Strings? [message #368126 is a reply to message #368121] |
Tue, 05 May 2009 14:31 |
In your sort expression try
parseInt( row["yourxmlstring" );
Jason
> <data order="1">
> </data>
> <data order="2">
> </data>
> <data order="10">
> </data>
> a string the result is the following order:
> 1
> 10
> 2
> instead of:
> 1
> 2
> 10
> integer or is it only possible to get the correct order if I change my
> XML format?
Re: Sorting on Strings? [message #368137 is a reply to message #368126] |
Tue, 05 May 2009 20:01 |
Hm seems that it parses the string to an integer automatically if I just
declare the columnmapping to have type Integer instead of type String -
nice.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:gtpihi$gpj$2@build.eclipse.org...
> Jason
>> <data order="1">
>> </data>
>> <data order="2">
>> </data>
>> <data order="10">
>> </data>
>> 1
>> 10
>> 2
>> instead of:
>> 1
>> 2
>> 10
>> XML format?
FUDForum. Page generated in 0.03182 seconds
