Re: Adding Custom Events [message #368124 is a reply to message #368109] |
Tue, 05 May 2009 14:29 |
Sushant,
There are a set of predefined events that you can implement handlers for
in Java or JavaScript, but there is no extension to add new ones.
There are extension points to add functions to the expression builder,
but this does not sound like what you want.
Jason
Sushant Dusad wrote:
> Hi All,
> I just want ot know if i can add custom events to BIRT that can be
> used by Javascript and Java.
> If yes the which is the extension point defined for that.
> Thanks and Regards
> Sushant Dusad
Re: Adding Custom Events [message #368132 is a reply to message #368128] |
Tue, 05 May 2009 15:37 |
Yes. If you post what you want to do, maybe I can tell which events you
need.
> Jason
> Thanks for the reply.
> So i need to see if i can use the same framework to get the required
> events.
> Thanks and Regards
> Sushant Dusad
> "Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
> news:gtpido$gpj$1@build.eclipse.org...
>> Sushant,
>> in Java or JavaScript, but there is no extension to add new ones. There
>> are extension points to add functions to the expression builder, but this
>> Jason
>>> Hi All,
>>> Thanks and Regards
>>> Sushant Dusad
Re: Adding Custom Events [message #368156 is a reply to message #368144] |
Thu, 07 May 2009 13:56 |
Sushant,
You can always add client side script to the report using
a text element and using the script tag ie
<script>
alert("my script");
</script>
Jason
> I want to replicate the Key Stroke Events
> news:gtpmdo$m4u$1@build.eclipse.org...
>> need.
>>> Jason
>>> events.
>>> Thanks and Regards
>>> Sushant Dusad
>>>> Sushant,
>>>> Jason
>>>>> Hi All,
>>>>> Thanks and Regards
>>>>> Sushant Dusad
FUDForum. Page generated in 0.03047 seconds
