Re: Exception in Unix Server [message #368119 is a reply to message #368098] |
Tue, 05 May 2009 14:02 |
Vignesh,
This error looks like the engine is null and failed to startup. Can you
post your code?
Jason
Vignesh.M wrote:
> This is the Stack Trace that i get
> java.lang.NullPointerException
> at
> org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:108)
> at
> org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:143)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:191)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:125)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:239)
> at com.i10n.fleet.util.ReportExporter.<init>(ReportExporter.java:52)
> at
> com.i10n.fleet.web.action.report.ReportAction.tripReport(Rep ortAction.java:4585)
> at com.i10n.fleet.util.MailUtils.sendMail(MailUtils.java:270)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> com.opensymphony.xwork2.DefaultActionInvocation.invokeAction (DefaultActionInvocation.java:404)
> at
> com.opensymphony.xwork2.DefaultActionInvocation.invokeAction Only(DefaultActionInvocation.java:267)
> at
> com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:229)
> at
> com.opensymphony.xwork2.interceptor.ConversionErrorIntercept or.intercept(ConversionErrorInterceptor.java:123)
> at
> com.opensymphony.xwork2.DefaultActionInvocation$2.doProfilin g(DefaultActionInvocation.java:224)
> at
> com.opensymphony.xwork2.DefaultActionInvocation$2.doProfilin g(DefaultActionInvocation.java:223)
> at
> com.opensymphony.xwork2.util.profiling.UtilTimerStack.profil e(UtilTimerStack.java:455)
> at
> com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:221)
> at
> com.opensymphony.xwork2.interceptor.ParametersInterceptor.do Intercept(ParametersInterceptor.java:167)
> at
> com.opensymphony.xwork2.interceptor.MethodFilterInterceptor. intercept(MethodFilterInterceptor.java:86)
> at
> at
> at
> at
> at
> org.apache.struts2.interceptor.CheckboxInterceptor.intercept (CheckboxInterceptor.java:83)
> at
> at
> at
> at
> at
> com.opensymphony.xwork2.interceptor.PrepareInterceptor.doInt ercept(PrepareInterceptor.java:121)
> at
> at
> at
> at
> at
> at
> org.apache.struts2.interceptor.ServletConfigInterceptor.inte rcept(ServletConfigInterceptor.java:170)
> at
> at
> at
> at
> at
> com.opensymphony.xwork2.interceptor.ExceptionMappingIntercep tor.intercept(ExceptionMappingInterceptor.java:176)
> at
> at
> at
> at
> at
> org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActi onProxy.java:50)
> at
> org.apache.struts2.dispatcher.Dispatcher.serviceAction(Dispa tcher.java:504)
> at
> org.apache.struts2.dispatcher.FilterDispatcher.doFilter(Filt erDispatcher.java:419)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:563)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:263)
> at
> org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler. java:190)
> at
> org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.ja va:283)
> at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java :767)
> at
> org.apache.jk.common.ChannelSocket.processConnection(Channel Socket.java:697)
> at
> org.apache.jk.common.ChannelSocket$SocketConnection.runIt(Ch annelSocket.java:889)
> at
> org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:690)
> at java.lang.Thread.run(Thread.java:619)
> Thanks in Advance
> Vignesh.M
FUDForum. Page generated in 0.04168 seconds
