Re: Possible to access the property editor from BIRT Engine? [message #368136 is a reply to message #368114] |
Tue, 05 May 2009 18:16 |
Originally posted by: asd.asd.com
I was wondering if there was a call in the API corresponding to pressing the
"refresh" button under table bindings.
Currently I have to manually do this in the report designer to make all the
columnmappings visible for a table in my application.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:gtpe04$41a$1@build.eclipse.org...
> You can add filters and bindings using the de api. Not certain if that is
> what you want.
> JS wrote:
>> Is it possible to access the Property Editor using the BIRT engine. I
>> especially think of the 'filters' and 'binding' pane.
Re: Possible to access the property editor from BIRT Engine? [message #368138 is a reply to message #368136] |
Tue, 05 May 2009 20:03 |
There is code to refresh to GUI portion that is not in the API.
You can take a look at what is done in the source under
DataSetColumnBindingsFormPage.java in the handleRefreshSelectEvent();
Jason
> the "refresh" button under table bindings.
> the columnmappings visible for a table in my application.
>> that is what you want.
FUDForum. Page generated in 0.03456 seconds
