Home » Eclipse Projects » Plugin Development Environment (PDE) » p2 director issue - "binary" and "ini" are missing
p2 director issue - "binary" and "ini" are missing [message #37578] Sat, 13 December 2008 03:32 Go to next message
Originally posted by: michael.zend.com
Hi All,
I think that I've created a good repository using p2 generator:
1. I've extracted non-p2 application using the following layout (I've looked
how PDE builder does this):
/tmp/App_source/
plugins/
features/
App/
App <-- executable
App.ini
configuration
2. My product file is looks like this:
<product name="%productName" id="com.my.app"
application="org.eclipse.ui.ide.workbench" version="1.0.0"
useFeatures="true">
<configIni use="default">
</configIni>
.... branding skipped ...
<features>
.... all features my product includes
</features>
</product>
3. Then I've run the following two commands:
~/devenv.michael/build/eclipse/eclipse -vm
/opt/jdk1.5.0_12/bin/java -application
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator -nosplash -debug
-consoleLog --launcher.suppressErrors \
-source /tmp/App_source -p2.os linux -p2.ws gtk -p2.arch
x86_64 -metadataRepository file:/tmp/repo -metadataRepositoryName "My
Repository" -artifactRepository file:/tmp/repo \
-artifactRepositoryName "My
Repository" -noDefaultIUs -append -compress -publishArtifacts -publishArtifactRepository
-vmargs -Xmx256m
-config /tmp/App_source/App -exe /tmp/App_source/App/App -productFile
~/devenv.michael/build/plugins/com.my.app/App.product -launcherConfig
linux_gtk_x86_64 \
-p2.os linux -p2.ws gtk -p2.arch x86_64 -metadataRepository
file:/tmp/repo -metadataRepositoryName "My Repository" -artifactRepository
file:/tmp/repo \
Repository" -append -compress -publishArtifacts -publishArtifactRepository -vmargs
-Xmx256m
4. The repository was created successfully (no errors reported), as follows:
/tmp/repo
plugins/ <--- all my plugins including dependencies
features/ <--- all my features including dependencies
binary/
com.my.app.launcher.gtk.linux.x86_64_6.1.0 <--- Zip containing my App
executable, ini file, configuration, etc...
content.jar
artifacts.jar
Now, I'm running p2 director in order to extract my application from the
repository:
1. Run the following command:
org.eclipse.equinox.p2.director.app.application -nosplash --launcher.suppressErrors
-consoleLog -debug \
-metadataRepository file:/tmp/repo -artifactRepository
file:/tmp/repo -installIU com.my.app -version 1.0.0 -roaming -profile
AppProfile -profileProperties org.eclipse.update.install.features=true \
-destination /tmp/App -bundlepool /tmp/App -p2.os linux -p2.ws
gtk -p2.arch x86_64 -vmargs -Declipse.p2.data.area=/tmp/App/p2 -Xmx256m
2. The output from the command was:
Installing com.my.app 1.0.0.
Operation completed in 76519 ms.
3. When looking at the destination directory /tmp/App, I find the following:
/tmp/App/
artifacts.xml
configuration
dropins
eclipse.ini
features
p2
plugins
First of all, there's no App executable and icons. Furthermore eclipse.ini
is not named like "App.ini"
Do you see any issues in the procedure presented above?
Thanks in advance!
Michael
Re: p2 director issue - "binary" and "ini" are missing [message #38021 is a reply to message #37578] Tue, 16 December 2008 21:43 Go to previous messageGo to next message
Michael,
Did you get a response to this ?
As a workaround we're copying the executable from the eclipse delta pack
and renaming it to what we need it to be.
-- Ketan
On 13/12/08 14:02, Michael Spector wrote:
> Hi All,
> /tmp/App_source/
> plugins/
> features/
> App/
> App<-- executable
> App.ini
> configuration
> useFeatures="true">
> </configIni>
> <features>
> </features>
> </product>
> -vmargs -Xmx256m
> linux_gtk_x86_64 \
> file:/tmp/repo \
> -Xmx256m
> /tmp/repo
> plugins/<--- all my plugins including dependencies
> features/<--- all my features including dependencies
> binary/
> com.my.app.launcher.gtk.linux.x86_64_6.1.0<--- Zip containing my App
> content.jar
> artifacts.jar
> repository:
> /tmp/App/
> artifacts.xml
> configuration
> dropins
> eclipse.ini
> features
> p2
> plugins
> Thanks in advance!
> Best regards,
> Michael
Re: p2 director issue - "binary" and "ini" are missing [message #38049 is a reply to message #38021] Wed, 17 December 2008 00:54 Go to previous message
No I didn't get any response. Thank you for your suggestion, but I don't
think it's an option :)
I've opened a bug about this issue: 259055
"Ketan Padegaonkar" <ketanpadegaonkar@gmail.com> wrote in message
news:gi9p16$fm7$1@build.eclipse.org...
> Michael,
> -- Ketan
>> Hi All,
>> looked
>> /tmp/App_source/
>> plugins/
>> features/
>> App/
>> App<-- executable
>> App.ini
>> configuration
>> useFeatures="true">
>> </configIni>
>> <features>
>> </features>
>> </product>
>> -vmargs -Xmx256m
>> linux_gtk_x86_64 \
>> file:/tmp/repo \
>> -vmargs
>> -Xmx256m
>> follows:
>> /tmp/repo
>> binary/
>> App
>> content.jar
>> artifacts.jar
>> repository:
>> following:
>> /tmp/App/
>> artifacts.xml
>> configuration
>> dropins
>> eclipse.ini
>> features
>> p2
>> plugins
>> eclipse.ini
>> Thanks in advance!
>> Best regards,
>> Michael
Re: p2 director issue - "binary" and "ini" are missing [message #587296 is a reply to message #37578] Tue, 16 December 2008 21:43 Go to previous message
Michael,
-- Ketan
> Hi All,
> /tmp/App_source/
> plugins/
> features/
> App/
> App<-- executable
> App.ini
> configuration
> useFeatures="true">
> </configIni>
> <features>
> </features>
> </product>
> -vmargs -Xmx256m
> linux_gtk_x86_64 \
> file:/tmp/repo \
> -Xmx256m
> /tmp/repo
> binary/
> content.jar
> artifacts.jar
> repository:
> /tmp/App/
> artifacts.xml
> configuration
> dropins
> eclipse.ini
> features
> p2
> plugins
> Thanks in advance!
> Best regards,
> Michael
Re: p2 director issue - "binary" and "ini" are missing [message #587318 is a reply to message #38021] Wed, 17 December 2008 00:54 Go to previous message
> Michael,
> -- Ketan
>> Hi All,
>> looked
>> /tmp/App_source/
>> plugins/
>> features/
>> App/
>> App<-- executable
>> App.ini
>> configuration
>> useFeatures="true">
>> </configIni>
>> <features>
>> </features>
>> </product>
>> -vmargs -Xmx256m
>> linux_gtk_x86_64 \
>> file:/tmp/repo \
>> -vmargs
>> -Xmx256m
>> follows:
>> /tmp/repo
>> binary/
>> App
>> content.jar
>> artifacts.jar
>> repository:
>> following:
>> /tmp/App/
>> artifacts.xml
>> configuration
>> dropins
>> eclipse.ini
>> features
>> p2
>> plugins
>> eclipse.ini
>> Thanks in advance!
>> Best regards,
>> Michael
Previous Topic:Absolute URLs in the config.ini generated by p2
Next Topic:Problem building plugin on ganymede with bundle-nativecode
Current Time: Thu Jul 17 19:51:17 EDT 2025
Powered by FUDForum. Page generated in 0.35075 seconds
