Home » Modeling » OCL » [Announce] MDT 1.1 development plan
[Announce] MDT 1.1 development plan [message #37575] Fri, 21 September 2007 10:02 Go to next message
Originally posted by: Kenn.Hussey.embarcadero.com
A draft of the development plan for MDT 1.1, targeted for June 2008 as part
of the Ganymede simultaneous release, has been posted at
http://www.eclipse.org/modeling/mdt/docs/plans/mdt_project_p lan_1_1.html.
Feedback is welcome.
Kenn
Re: [Announce] MDT 1.1 development plan [message #37998 is a reply to message #37575] Mon, 24 September 2007 11:16 Go to previous messageGo to next message
> Kenn
I would suggest adding an dev plan item for a reusable OCL widget for
edition purpose.
[OCL Tools component]:{Reusable OCL editor widget}
My idea would be to give user possibility to embbed such OCL widget as
part of their tools UI (eg: inside wizard page, console page, tabbed
propeties page, search page, ....).
Maybe could we inspire ourselve from the OCL interpreter example coming
from EMFT Query, having a MDT OCLViewer with M1/M2 support for OCL
editing, based on the MDT OCL Parser.
I already have a need for such feature in [EMFT Search] and can offer
reasonible contribution effort for that.
regards,
Re: [Announce] MDT 1.1 development plan [message #38158 is a reply to message #37998] Mon, 24 September 2007 15:04 Go to previous messageGo to next message
Lucas,
I'm sure Miguel will give your suggestion (and contribution!) due
consideration when he puts together more detailed development plans for the
Ganymede release... at this point, the OCL Tools component has yet to be
provisioned. :(
Kenn
"lb" <lucas.bigeardel@anyware-tech.com> wrote in message
news:fd8kcr$e9d$1@build.eclipse.org...
> Kenn Hussey a
Re: [Announce] MDT 1.1 development plan [message #38318 is a reply to message #38158] Tue, 25 September 2007 03:58 Go to previous messageGo to next message
> Lucas,
> provisioned. :(
> Kenn
Kenn,
I'll take some time to talk with Miguel about that.
cheers,
- Lucas
>>> part of the Ganymede simultaneous release, has been posted at
>>> Kenn
>> edition purpose.
>> regards,
Re: [Announce] MDT 1.1 development plan [message #43030 is a reply to message #37575] Wed, 07 November 2007 01:41 Go to previous messageGo to next message
Hi Kenn,
One area where the UML API is particularly weak on is protecting itself
in cases where exceptions are triggered precisely because something has
made the model ill-formed - e.g., a circular containment hierarchy, a
circular generalization hierarchy, etc... In some cases (e.g., circular
containment induced from a package merge operation gone bad), we can
even induce an infinite loop in the exception handling code that
attempts to undo the mess. I observed these things in the Eclipse 3.2
environment I work with (uml 2.0.4) From the CVS logs, I am not sure if
the issues are still there or not. If they are, is this the sort of
issue that could be considered for the MDT 1.1 plan?
-- Nicolas.
> Kenn
Re: [Announce] MDT 1.1 development plan [message #43051 is a reply to message #43030] Wed, 07 November 2007 10:46 Go to previous message
Hi Nicolas,
If possible, could you please raise specific defects (with steps to
reproduce the problem).
Contributions from the community regarding filling out the various
validation functions is always welcomed ;).
- James.
"Nicolas Rouquette" <nicolas.rouquette@jpl.nasa.gov> wrote in message
news:47315E30.4040903@jpl.nasa.gov...
> Hi Kenn,
> One area where the UML API is particularly weak on is protecting itself in
> cases where exceptions are triggered precisely because something has made
> the model ill-formed - e.g., a circular containment hierarchy, a circular
> generalization hierarchy, etc... In some cases (e.g., circular containment
> induced from a package merge operation gone bad), we can even induce an
> infinite loop in the exception handling code that attempts to undo the
> mess. I observed these things in the Eclipse 3.2 environment I work with
> (uml 2.0.4) From the CVS logs, I am not sure if the issues are still there
> or not. If they are, is this the sort of issue that could be considered
> Cheers,
> -- Nicolas.
>> Kenn
Previous Topic:Re: Referencing attribute of target class in message of OCL Constraint
Next Topic:how to create a TupleType?
Current Time: Sat Aug 02 04:17:42 EDT 2025
Powered by FUDForum. Page generated in 0.03668 seconds
