Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #40085 is a reply to message #37807] |
Wed, 19 December 2007 11:56  |
Originally posted by: brianf.sybase.com
Hi Lars...
Can you create a BZ entry for this so we can take a look at it for the
Ganymede release?
--Fitz
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:fg5gvv$eau$1@build.eclipse.org...
> Hi Brian,
> I use:
> Derby Embedded Database and Derby v. 10.2.2.0.
> The statement I'm running is
> create schema sixsigma;
> I have the database connected while running the statement. F5 / right
> mouse click -> refresh does not show the new schema. After disconnect and
> connect the schema is visible.
> Best regards, Lars
> "Brian Fitzpatrick" <brianf@sybase.com> wrote in message
> news:fg557k$pmu$1@build.eclipse.org...
>> Hi Lars...
>> What are you using as your profile and DBMS to reproduce this? We can
>> take a look. But typically if you right-click on the root node under the
>> profile in the DSE and select Refresh, it should pick up your changes.
>> --Brian Fitzpatrick
>> news:fft150$agq$1@build.eclipse.org...
>>> Hi,
>>> If I create a SQL script to create a schema and run it I have to
>>> disconnect and connect to the database to get this schema displayed.
>>> Is this a bug which I should report via bugzilla?
>>> Best regards, Lars
Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #588350 is a reply to message #37719] |
Mon, 29 October 2007 16:49  |
Hi Brian,
I use:
I have the database connected while running the statement. F5 / right mouse
click -> refresh does not show the new schema. After disconnect and connect
Best regards, Lars
> Hi Lars...
> What are you using as your profile and DBMS to reproduce this? We can take
> --Brian Fitzpatrick
>> Best regards, Lars
Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #589422 is a reply to message #37807] |
Hi Lars...
Ganymede release?
--Fitz
> Hi Brian,
> I use:
> Best regards, Lars
>> Hi Lars...
>> --Brian Fitzpatrick
>>> Hi,
>>> Best regards, Lars
FUDForum. Page generated in 0.08210 seconds
