Home » Eclipse Projects » GEF » about flowlayout again(one picture worth thousand words)
Re: about flowlayout again(one picture worth thousand words) [message #37455 is a reply to message #37421] |
Wed, 30 October 2002 09:59   |
I assume you want something like
| ggggggg rrrrrrrrr|
| gggg rrrrr|
| gggggg rrrrrrr|
| gg rrrrrrrr|
| ggggg r|
You could nest two vertical FlowLayouts (the second set to
ALIGN_RIGHTBOTTOM) inside a horizontal FlowLayout (with setFill(true).
Hope this helps,
-- Scott
Scott Stanchfield scott@javadude.com http://javadude.com
Lead author of "Effective VisualAge for Java, Version 3"
http://javadude.com/evaj
VisualAge for Java Tips and Tricks http://javadude.com/vaj
Visit for Java Enlightenment! http://www.jguru.com
"Ozgur Kurt" <ozgurkurt@hotmail.com> wrote in message
news:apoltt$1k3$1@rogue.oti.com...
> hi all,
> Randy, and Scott, i've looked at what you've advised in previous posts. I
> just attached a picture, please have a look at it. what i need is say
greens
> are on left, and reds are right side, like two independent flowlayouts...
> any idea to make this job easier without implementing a sort of
flowlayout?
> thanx,
> ozgur
Re: about flowlayout again(one picture worth thousand words) [message #37553 is a reply to message #37455] |
Wed, 30 October 2002 10:35   |
Originally posted by: hudsonr.us.eye-bee-em.com
To nest two layouts, and two figures, you'd end up with 2 sets of children,
and therefore you probably need more EditParts to manage the two different
children sets. This is possible.
I did exactly the same thing for a UML class. I had a UMLClassEditPart. It
had two FeaturePanelEditParts (corresponding to 2 bogus model objects for
each feature). Each "Feature Panel" had its own set of children, for
example "attributes", and "operations". The FeaturePanels can be made
completely unknown at edit time by having them not register their Figures in
the VisualPartMap.
We probably need better support for EditPArts that are not selectable. If
anyone is pursuing such EditParts for the purpose of grouping multiple sets
of children, then let me know about it so we can better support this.
"Scott Stanchfield" <scott@javadude.com> wrote in message
news:apoqbq$4ch$1@rogue.oti.com...
> | ggggggg rrrrrrrrr|
> | gggg rrrrr|
> | gggggg rrrrrrr|
> | gg rrrrrrrr|
> | ggggg r|
> Hope this helps,
> -- Scott
> > hi all,
I
> greens
flowlayouts...
> flowlayout?
> > thanx,
> > ozgur
Re: about flowlayout again(one picture worth thousand words) [message #37953 is a reply to message #37553] |
Wed, 30 October 2002 20:56   |
Originally posted by: sy_cheung2.yahoo.com
Randy,
Could you pleaes clarify what you mean by "not register their figures in the
VisualPartMap", is there a method call for doing that.
I am doing a similar thing (group children into multiple sets and the group
editpart is not selectable), I appreciate if you can share your experience.
Thank you.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aposjn$60h$1@rogue.oti.com...
children,
It
in
> the VisualPartMap.
sets
> > | ggggggg rrrrrrrrr|
> > | gggg rrrrr|
> > | gggggg rrrrrrr|
> > | gg rrrrrrrr|
> > | ggggg r|
> > Hope this helps,
> > -- Scott
> > > hi all,
posts.
> I
> > greens
> flowlayouts...
> > flowlayout?
> > > thanx,
> > > ozgur
Re: about flowlayout again(one picture worth thousand words) [message #38148 is a reply to message #37953] |
Thu, 31 October 2002 08:39  |
registerVisuals(). This affects more than just selection. As a result of
this, creation, moving, and all other forms of targeting will also not see
the EditPart. That is why I want to propose a isSelectable() API on
EditPart. You would still be able to target the groups if you want, but
clicking on them will select the groups parent.
-randy
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:apq0rq$s86$1@rogue.oti.com...
> Randy,
the
group
experience.
> Thank you.
> children,
different
> It
for
Figures
> in
> > the VisualPartMap.
If
> sets
> > > | ggggggg rrrrrrrrr|
> > > | gggg rrrrr|
> > > | gggggg rrrrrrr|
> > > | gg rrrrrrrr|
> > > | ggggg r|
> > > Hope this helps,
> > > -- Scott
> > > > hi all,
> posts.
> > I
say
> > > greens
> > flowlayouts...
> > > flowlayout?
> > > > thanx,
> > > > ozgur
Current Time: Sat Aug 23 15:43:23 EDT 2025
Powered by FUDForum. Page generated in 0.62536 seconds
