Home » Eclipse Projects » DSDP - Target Management » RSE daemon.pl on AIX throws MalformedInputException
RSE daemon.pl on AIX throws MalformedInputException [message #37405] Wed, 15 July 2009 07:48 Go to next message
I'm trying to connect from a Windows XP Eclipse 3.5 using a DStore
Connection to a AIX machine where I started the daemon as a root user.
As soon as I try to open a connection in eclipse, the daemon throws an
error, and no connection can be established.
Anyone know what could be wrong with my setup ?
The 'uninitialized value ' warnings show up because DSTORE_TRACING_ON and
CLASSPATH are not set.
I set DSTORE_TRACING_ON to true and CLASSPATH to '.' but it didn't help,
so i guess those errors are not the cause of the problem.
/daemon.pl &
[1] 37422
root@srv [163]>
Use of uninitialized value in concatenation (.) or string at ./daemon.pl
line 48.
line 56.
Daemon running on: srv, port: 4035
root@srv [164]> sun.io.MalformedInputException
at sun.io.ByteToCharUTF8.convert(ByteToCharUTF8.java:262)
sun.nio.cs.StreamDecoder$ConverterSD.convertInto(StreamDecod er.java:314)
sun.nio.cs.StreamDecoder$ConverterSD.implRead(StreamDecoder. java:364)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:250)
at java.io.InputStreamReader.read(InputStreamReader.java:212)
at java.io.BufferedReader.fill(BufferedReader.java:157)
at java.io.BufferedReader.readLine(BufferedReader.java:320)
at java.io.BufferedReader.readLine(BufferedReader.java:383)
org.eclipse.dstore.core.server.ServerLauncher$ConnectionList ener.listen(ServerLauncher.java:207)
org.eclipse.dstore.core.server.ServerLauncher$ConnectionList ener.run(ServerLauncher.java:113)
Exception in thread "Thread-2" java.lang.NullPointerException
at java.io.Writer.write(Writer.java:147)
org.eclipse.dstore.core.server.ServerLauncher$ConnectionList ener.listen(ServerLauncher.java:292)
Re: RSE daemon.pl on AIX throws MalformedInputException [message #37439 is a reply to message #37405] Thu, 16 July 2009 13:08 Go to previous messageGo to next message
Are you sure you got the "rseserver-3.1-unix.tar" version of the
daemon? The source code of daemon.pl seems to be empty in lines
48 and 56, so I am wondering what version you have.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> and CLASSPATH are not set.
> /daemon.pl &
> [1] 37422
> root@srv [163]> Use of uninitialized value in concatenation (.) or
> string at ./daemon.pl line 48.
> line 56.
> at
> at
> at
> at
> at
> at
Re: RSE daemon.pl on AIX throws MalformedInputException [message #37508 is a reply to message #37439] Fri, 17 July 2009 03:33 Go to previous message
ah, sorry, i was somehow using version 1.0, i wonder where i got that from.
Using 3.1 works. Thanks for the hint!
> daemon?
Re: RSE daemon.pl on AIX throws MalformedInputException [message #581997 is a reply to message #37405] Thu, 16 July 2009 13:08 Go to previous message
> /daemon.pl &
> [1] 37422
> line 56.
> at
> at
> at
> at
> at
> at
Re: RSE daemon.pl on AIX throws MalformedInputException [message #582036 is a reply to message #37439] Fri, 17 July 2009 03:33 Go to previous message
> daemon?
Previous Topic:The RSE org.eclipse.rse.importexport plugin execution environments level?
Next Topic:Empty List when using FTP
Current Time: Tue May 27 22:31:56 EDT 2025
Powered by FUDForum. Page generated in 0.05065 seconds
