Home » Language IDEs » PHP Development Tools (PDT) » How Do I Get Debugging Working?
How Do I Get Debugging Working? [message #37402] Thu, 19 July 2007 15:49 Go to next message
Originally posted by: DWTebriel.gmail.com
I am trying to figure out how to install the debug extension into PHP
and get it functioning within pdt. I currently have the following versions:
Windows XP Pro
Eclipse 3.3.0
PDT 1.0 M1
Apache 2.2.4
PHP 5.2.3
I would like to get the Zend Debugger to work. However I am also willing
to try out XDebug. I have just tried both, and neither worked. However I
was able to get PHP to show that XDebug could be installed under
phpinfo. It doesn't seem that Zend Debugger is updated enough to be
installed into PHP 5.2.x. I think I found some debug site for XDebug
integration into PDT 0.7, however I really don't want to downgrade my
PDT installation.
I've tried to Google for an answer, but I can't seem to find anything
that is up-to-date. Any help would be greatly appreciated, cause right
now I have resorted to sticking var_dumps and echos all over the place. :D
Paul
Paul
Web Application Team Member
Instructional, Communication, and Information Technology
UW Whitewater
Re: How Do I Get Debugging Working? [message #37436 is a reply to message #37402] Thu, 19 July 2007 15:59 Go to previous messageGo to next message
Originally posted by: mshekov.gmx.de
About ZEND Debugger: Have you followed
a) what is stated in the Zend Debugger Readme (inside the zip file)
b) checked that also these things are done correctly?:
http://www.thierryb.net/pdtwiki/index.php?title=Using_PDT_:_ Installation_:_Installing_the_Zend_Debugger
If so, you should actually get the confirmation that the Zend debugger
is working by having a look at the phpinfo() output.
Good luck!
Re: How Do I Get Debugging Working? [message #37469 is a reply to message #37436] Thu, 19 July 2007 16:44 Go to previous messageGo to next message
> Good luck!
Well, I got that installed. Thanks for the link. Is there any support
for breakpoints however?
Paul Sanchez
UW Whitewater
Re: How Do I Get Debugging Working? [message #37502 is a reply to message #37402] Thu, 19 July 2007 21:19 Go to previous messageGo to next message
Originally posted by: mkgrnwlt.aol.com
Based on my own experience with PDT, and on seeing numerous posts to this
group, it seems that debugging with PDT is NOT an easy thing to accomplish.
I have been trying off and on for a couple of weeks to get debugging to
work, and so far, no luck. The needed information seems to be fairly
scattered, and not simply located at the site that sources the software.
That seems a strange situation indeed.
I have been trying to link to the site at thierryb.net for weeks, and could
not even establish a connection, much less read the material. Finally, today
I am able to access that site. Who knows why it would not work for me
before?
Fortunately, I was able to complete my first PHP project by using echo calls
to print out debug data.
-- Mike
"Paul Sanchez" <DWTebriel@gmail.com> wrote in message
news:f7of8a$3as$1@build.eclipse.org...
> Hello,
> I am trying to figure out how to install the debug extension into PHP and
> Windows XP Pro
> Eclipse 3.3.0
> PDT 1.0 M1
> Apache 2.2.4
> PHP 5.2.3
> was able to get PHP to show that XDebug could be installed under phpinfo.
> It doesn't seem that Zend Debugger is updated enough to be installed into
> PHP 5.2.x. I think I found some debug site for XDebug integration into PDT
> 0.7, however I really don't want to downgrade my PDT installation.
> I've tried to Google for an answer, but I can't seem to find anything that
> is up-to-date. Any help would be greatly appreciated, cause right now I
> Paul
> Paul
> UW Whitewater
Re: How Do I Get Debugging Working? [message #37536 is a reply to message #37502] Fri, 20 July 2007 00:32 Go to previous messageGo to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Yeah, I have never been able to get it working. Mostly because my files
are stored on a separate server and the path mapping stuff is pretty
alpha still.
That said, the guys who've done what currently exists have done a great
job considering how gnarly path management can get.
But I do really wish the main PDT guys would get the debugging issue
sorted, incorporate the xdebug plugin and get the path mapping sorted
out... and make it a little less painful to get happening without having
to trawl 6 different readme's and forums and newsgroups.
> before?
> -- Mike
>> Hello,
>> Windows XP Pro
>> Eclipse 3.3.0
>> PDT 1.0 M1
>> Apache 2.2.4
>> PHP 5.2.3
>> Thanks,
>> Paul
>> Paul
>> UW Whitewater
Re: How Do I Get Debugging Working? [message #37692 is a reply to message #37469] Fri, 20 July 2007 11:39 Go to previous message
>> Good luck!
Well, for those who are interested, I have the breakpoints working now.
You just have to set the option under General -> Web Browser to external
web browser. For some reason internal wasn't working right. Yay for
debugging :D.
Paul Sanchez
Instructional, Communication and Information Technology
UW Whitewater
Previous Topic:Cannot open file in PHP editor
Next Topic:Problem - PDT and Subclipse
Current Time: Wed Jun 25 08:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.12876 seconds
