Home » Eclipse Projects » Eclipse Platform » XML Parser
XML Parser [message #37362] Mon, 19 May 2003 04:31 Go to next message
Originally posted by: lovoni6.hotmail.com
Hi Everybody!
I tried to parse an xml file using the following code
public void processFile() {
try {
DocumentBuilder
docBuilder=DocumentBuilderFactory.newInstance().newDocumentB uilder();
Document
doc=docBuilder.parse("c:\\resources\\files\\Miscellaneous.xml ");
//org.w3c.dom.Document
NodeList list=doc.getChildNodes();
//org.w3c.dom.NodeList
for (int ii = 0; ii < list.getLength(); ii++) {
System.out.println(list.item(ii).getNodeName());
// returns the node name
System.out.println(list.item(ii).getNodeValue());
//returns null
NodeList list1=list.item(ii).getChildNodes();
for (int jj = 0; jj < list1.getLength(); jj++) {
System.out.println("\t"+list1.item(jj).getNodeName());
System.out.println("\t"+list1.item(jj).getNodeValue());
//returns null
NodeList list2=list1.item(jj).getChildNodes();
catch(Exception e){}
but all calls to Node.getNodeValue() return null.
How can I solve the problem? Is there another mean(classes), within the
eclipse platform, to parse xml file and get node values?
Thanks for help.
Re: XML Parser [message #37529 is a reply to message #37362] Mon, 19 May 2003 06:36 Go to previous message
It works with the following code
try {
DocumentBuilderImpl
docBuilder=DocumentBuilderFactoryImpl.newInstance().newDocum entBuilder();
DocumentImpl
//org.apache.xerces.dom.DocumentImpl
NodeImpl node=(NodeImpl )list.item(ii);
System.out.println(node.getNodeName());
System.out.println(node.getTextContent());
"Castor" <lovoni6@hotmail.com> wrote in message
news:baa4gb$lu4$1@rogue.oti.com...
> Hi Everybody!
> try {
> DocumentBuilder
> Document
> //returns null
> //returns null
> Thanks for help.
Previous Topic:Unicode support in standard Eclipse views?
Next Topic:A date for Eclipse 2.1.1
Current Time: Fri Jul 18 00:48:37 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
