Home » Eclipse Projects » Mylyn » Mylyn not able to update bugzilla.
Mylyn not able to update bugzilla. [message #37345] Mon, 26 November 2007 05:14 Go to next message
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigDC83D03F8C05BCF6BE8EAE9A
Content-Type: text/plain; charset=ISO-8859-1
This is slightly off-topic, but I thought I'd ask this here before
posting on the bugzilla mailing list.
I'm using Mylyn-2.1.0 to connect to bugzilla located at
(http://swtbot.org/bugzilla)
I'm able to use mylyn to query and get bugzilla tasks. I'm not able to
submit changes to a task using the mylyn connector.
It seems there's some cookie issue that I'm facing where the various
http connections to bugzilla do not use the same cookie.
Here's the request header that I'm able to sniff:
POST /bugzilla/process_bug.cgi HTTP/1.1
Content-Type: application/x-www-form-urlencoded; charset=3DUTF-8
User-Agent: Eclipse Mylyn (HttpClient/3.0.1)
Host: swtbot.org
Content-Length: 650
The content of the post is:
target_milestone=3D0.1.0&delta_ts=3D2007-11-26+00%3A38%3 A31&cclist_access=
ible=3D1&desc=3Dfail%28%29&everconfirmed=3D1&res olution=3D&bug_id=3D2&ver=
sion=3DHEAD&id=3D2&op_sys=3DLinux&component=3DEc lipseBot&priority=3DP5&re=
porter_accessible=3D1&qa_contact=3D&blocked=3D&k nob=3Dnone&classification=
_id=3D1&dependson=3D&keywords=3D&bug_status=3DRE OPENED&bug_file_loc=3D&ne=
w_comment=3Dthis+is+another+test1&bug_severity=3Denhance ment&short_desc=3D=
testThatBugzillaSendsEmailNotification.&assigned_to=3DKe tanPadegaonkar%2B=
SWTBot-admin%40gmail.com&product=3DSWTBot&form_name= 3Dprocess_bug&status_=
whiteboard=3D&classification=3DUnclassified&longdesc length=3D6&comment=3D=
this+is+another+test1&deadline=3D&rep_platform=3DPC& amp;newcc=3D
I don't see any cookie headers or login information being sent by mylyn.
I'm able to hit this url from the browser to update the bug (the URL is
the content of the http post above)
http://swtbot.org/bugzilla/process_bug.cgi?target_milestone= 3D0.1.0&delta=
_ts=3D2007-11-26+00%3A38%3A31&cclist_accessible=3D1& desc=3Dfail%28%29&eve=
rconfirmed=3D1&resolution=3D&bug_id=3D2&version= 3DHEAD&id=3D2&op_sys=3DLi=
nux&component=3DEclipseBot&priority=3DP5&reporte r_accessible=3D1&qa_conta=
ct=3D&blocked=3D&knob=3Dnone&classification_id=3 D1&dependson=3D&keywords=3D=
&bug_status=3DREOPENED&bug_file_loc=3D&new_comme nt=3Dthis+is+another+test=
1&bug_severity=3Denhancement&short_desc=3DtestThatBu gzillaSendsEmailNotif=
ication.&assigned_to=3DKetanPadegaonkar%2BSWTBot-admin%4 0gmail.com&produc=
t=3DSWTBot&form_name=3Dprocess_bug&status_whiteboard =3D&classification=3D=
Unclassified&longdesclength=3D6&comment=3Dthis+is+an other+test1&deadline=3D=
&rep_platform=3DPC&newcc=3D
Is there some special configuration that bugzilla needs ?
--=20
Ketan Padegaonkar
I blog... therefore I am... http://ketan.padegaonkar.name/
The farther you go, the less you know.
-- Lao Tsu, "Tao Te Ching"
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHSpxv50uB2zvyE8MRAivCAJ9Fyq5GFubIcKaDYGMeesimECneuwCg kC/G
7Ps2T+ZKY/IPusQ1TsNIz5w=
=jCgI
-----END PGP SIGNATURE-----
--------------enigDC83D03F8C05BCF6BE8EAE9A--
Re: Mylyn not able to update bugzilla. [message #37379 is a reply to message #37345] Mon, 26 November 2007 05:29 Go to previous message
--------------enigD2680BE2039DDBB97128C812
>=20
>=20
>=20
<snipped />
Here's what I figured out:
The cookie domain for http://swtbot.org/bugzilla was set to
".swtbot.org" so that subdomains could use this cookie. Turning this off
(by setting it to null) seems to have worked.
--=20
Ketan Padegaonkar
iD8DBQFHSp/250uB2zvyE8MRAnRnAKCq7l2p4sKL+piNdOJOtfrDL4digwCf Y17m
JbMYrBsIT2csz7+2BAsVeME=
=pAHP
--------------enigD2680BE2039DDBB97128C812--
Re: Mylyn not able to update bugzilla. [message #585188 is a reply to message #37345] Mon, 26 November 2007 05:29 Go to previous message
>=20
>=20
>=20
<snipped />
--=20
Ketan Padegaonkar
=pAHP
Previous Topic:Add CC to a new bug(zilla) with Mylyn
Next Topic:Error updating attributes - new Mylyn installation, new query
Current Time: Sat Jul 19 01:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.03877 seconds
