Home » Eclipse Projects » Eclipse Platform » JUnit behaving badly
JUnit behaving badly [message #37193] Mon, 19 May 2003 01:36
I have 2 weird issues and before I open a bug, hopefully someone here can
shed some light.
1.) I have wriiten an EJB and successfully deployed it. I then proceeded to
create a JUnit TestCase in eclipse. The creation of the testcase was fine,
but running it causes an error ( see stacktrace below). The test needs to
take a password, run it through MD5 and then base 64 encode the result
(method included below). If I execute the testcase from the command line
then all is well but from within eclipse I get the following:
..java.security.NoSuchAlgorithmException: Algorithm HmacMD5 not available
at javax.crypto.SunJCE_b.a(DashoA6275)
at javax.crypto.Mac.getInstance(DashoA6275)
at com.watutech.ejb.common.util.Utils.getMD5Hash(Utils.java:59)
com.watutech.firestorm.tests.UserBeanTest.testEjbCreate(User BeanTest.java:51
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at junit.textui.TestRunner.doRun(TestRunner.java:116)
at junit.textui.TestRunner.doRun(TestRunner.java:109)
at junit.textui.TestRunner.run(TestRunner.java:72)
at com.watutech.firestorm.tests.AllTests.main(AllTests.java:19)
Time: 2.193
OK (1 test)
I've checkd that I'm running in a 1.4 vm so the testcase does have access to
the required files, and running it on the command line verifies that it is
working.
public static String encode( String text )
try
Mac mac = Mac.getInstance("HmacMD5");
SecretKeySpec sk =
new SecretKeySpec("my secret".getBytes(), "HmacMD5");
mac.init(sk);
byte[] result = mac.doFinal( text.getBytes());
BASE64Encoder b64Encoder = new BASE64Encoder();
return b64Encoder.encode( result );
catch (InvalidKeyException e)
e.printStackTrace();
catch (NoSuchAlgorithmException e)
catch (IllegalStateException e)
return null;
2.) I used eclipse to create a TestSuite, AllTests and selected to include a
main method and to use the junit.textui.TestRunner. The main method
generated was:
public static void main(String[] args)
junit.textui.TestRunner.run(AllTests.class);
but I had to change it to
junit.textui.TestRunner.run(AllTests.suite());
to get it to work. Otherwise I got the following exception:
..F
Time: 0.01
There was 1 failure:
1) warning(junit.framework.TestSuite$1)junit.framework.Assertio nFailedError:
No tests found in com.watutech.firestorm.tests.AllTests
FAILURES!!!
Tests run: 1, Failures: 1, Errors: 0
The documentation seems to indicate that the run(Class) method will extract
all test*() methods, put them in a suite and run that, but since there are
no test*() methods in AllTests I get the warning. So is this a code
generation bug or did I miss something?
Binyan
Previous Topic:can't start eclipse
Next Topic:Palette for wizard banner
Current Time: Sat Aug 02 11:20:58 EDT 2025
Powered by FUDForum. Page generated in 0.03004 seconds
