Home » Archived » XML Schema Definition (XSD) » How to provide a different schema content
How to provide a different schema content [message #37145] Wed, 11 February 2004 18:34 Go to next message
In FAQ section of eclipse/xsd, it has the following question:
Is there a way to have schema documents which reference other schema
documents through <include> <import> or <redefine> be fetched from
locations other than those given in the schemaLocation attribute?
Yes, you can use a ResourceSet's URIConverter's URI map to map logical
URIs to physical URIs. You can see an example of that code in
XSDProtocotypicalSchema traceLoading().
But if I want to provide the content of the schema directly, instead of
letting EMF to locate the resource, how can I do it? Basically, what I
want is something like what EntityResolver provides.
Thanks.
Joshua
Re: How to provide a different schema content [message #37248 is a reply to message #37145] Thu, 12 February 2004 09:39 Go to previous message
Joshua,
Have a look at the new XSDSchemaLocator API. That should give you a hook
for populating a schema into the resource set using your own mechanism.
Joshua Hui wrote:
> Thanks.
> Joshua
Re: How to provide a different schema content [message #583457 is a reply to message #37145] Thu, 12 February 2004 09:39 Go to previous message
Joshua,
Joshua Hui wrote:
> Thanks.
> Joshua
Previous Topic:Unresolved element when validate using DOM format
Next Topic:ClassCastException in XSDSchemaImpl
Current Time: Fri Aug 08 02:12:47 EDT 2025
Powered by FUDForum. Page generated in 0.03222 seconds
