Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » 'package require' doesn't works when new a project
'package require' doesn't works when new a project [message #37061] Mon, 04 May 2009 23:33 Go to next message
my dltk version:
dltk-tcl-sdk-R-0.95.1-200809201836-incubation
1. i configurate a tcl interpreter in the preferences page,and configurate
its lib paths manually;
2. new a tcl project
3. new a source folder and a script, then i use 'package require' with the
key Alt+/ to show autocomplete package name list ,but there is nothing.
when i use Ctrl + F1, pop-up a NPE,
4.if i add a user lib to this project , the 'package require' autocomplete
will work well.
i want to know why? how to reslove it?
NPE:
Caused by: java.lang.NullPointerException
org.eclipse.dltk.tcl.internal.core.packages.PackagesManager. getPathsForPackage(PackagesManager.java:352)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .isFixable(TclCorrectionProcessor.java:160)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .isFixable(TclCorrectionProcessor.java:135)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .hasCorrections(TclCorrectionProcessor.java:184)
org.eclipse.dltk.tcl.internal.ui.TclUILanguageToolkit.hasCor rections(TclUILanguageToolkit.java:142)
org.eclipse.dltk.internal.ui.editor.ScriptAnnotationUtils.ha sCorrections(ScriptAnnotationUtils.java:39)
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider$ProblemAnnotation.initializeImage(SourceModuleDocumentP rovider.java:250)
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider$ProblemAnnotation.paint(SourceModuleDocumentProvider.ja va:303)
org.eclipse.ui.texteditor.DefaultMarkerAnnotationAccess.pain t(DefaultMarkerAnnotationAccess.java:247)
org.eclipse.jface.text.source.AnnotationRulerColumn.doPaint1 (AnnotationRulerColumn.java:767)
org.eclipse.jface.text.source.AnnotationRulerColumn.doubleBu fferPaint(AnnotationRulerColumn.java:518)
org.eclipse.jface.text.source.AnnotationRulerColumn.redraw(A nnotationRulerColumn.java:797)
org.eclipse.jface.text.source.AnnotationRulerColumn$6.run(An notationRulerColumn.java:784)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 22 more
Re: 'package require' doesn't works when new a project [message #37197 is a reply to message #37061] Tue, 12 May 2009 02:07 Go to previous message
Hi loulis,
Would you please try with latest 1.0 milestone or integration builds?
This part was completely rewritten in 1.0, so let's check if it works
with your project configuration.
Alex
loulis wrote:
> my dltk version:
> configurate its lib paths manually;
> the key Alt+/ to show autocomplete package name list ,but there is
> nothing. when i use Ctrl + F1, pop-up a NPE,
> autocomplete will work well.
> NPE:
> at
> at
> at
> at
> at
> at
> org.eclipse.dltk.internal.ui.editor.ScriptAnnotationUtils.ha sCorrections(ScriptAnnotationUtils..java:39)
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
Previous Topic:Guide to build IDE
Next Topic:Unresolve "package require Expect" in tcl project
Current Time: Thu Aug 21 15:12:47 EDT 2025
Powered by FUDForum. Page generated in 0.03170 seconds
