'package require' doesn't works when new a project [message #37061] |
Mon, 04 May 2009 23:33  |
my dltk version:
dltk-tcl-sdk-R-0.95.1-200809201836-incubation
1. i configurate a tcl interpreter in the preferences page,and configurate
its lib paths manually;
2. new a tcl project
3. new a source folder and a script, then i use 'package require' with the
key Alt+/ to show autocomplete package name list ,but there is nothing.
when i use Ctrl + F1, pop-up a NPE,
4.if i add a user lib to this project , the 'package require' autocomplete
will work well.
i want to know why? how to reslove it?
NPE:
Caused by: java.lang.NullPointerException
org.eclipse.dltk.tcl.internal.core.packages.PackagesManager. getPathsForPackage(PackagesManager.java:352)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .isFixable(TclCorrectionProcessor.java:160)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .isFixable(TclCorrectionProcessor.java:135)
org.eclipse.dltk.tcl.internal.ui.text.TclCorrectionProcessor .hasCorrections(TclCorrectionProcessor.java:184)
org.eclipse.dltk.tcl.internal.ui.TclUILanguageToolkit.hasCor rections(TclUILanguageToolkit.java:142)
org.eclipse.dltk.internal.ui.editor.ScriptAnnotationUtils.ha sCorrections(ScriptAnnotationUtils.java:39)
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider$ProblemAnnotation.initializeImage(SourceModuleDocumentP rovider.java:250)
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider$ProblemAnnotation.paint(SourceModuleDocumentProvider.ja va:303)
org.eclipse.ui.texteditor.DefaultMarkerAnnotationAccess.pain t(DefaultMarkerAnnotationAccess.java:247)
org.eclipse.jface.text.source.AnnotationRulerColumn.doPaint1 (AnnotationRulerColumn.java:767)
org.eclipse.jface.text.source.AnnotationRulerColumn.doubleBu fferPaint(AnnotationRulerColumn.java:518)
org.eclipse.jface.text.source.AnnotationRulerColumn.redraw(A nnotationRulerColumn.java:797)
org.eclipse.jface.text.source.AnnotationRulerColumn$6.run(An notationRulerColumn.java:784)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 22 more
Re: 'package require' doesn't works when new a project [message #37197 is a reply to message #37061] |
Tue, 12 May 2009 02:07  |
Hi loulis,
Would you please try with latest 1.0 milestone or integration builds?
This part was completely rewritten in 1.0, so let's check if it works
with your project configuration.
Alex
loulis wrote:
> my dltk version:
> configurate its lib paths manually;
> the key Alt+/ to show autocomplete package name list ,but there is
> nothing. when i use Ctrl + F1, pop-up a NPE,
> autocomplete will work well.
> NPE:
> at
> at
> at
> at
> at
> at
> org.eclipse.dltk.internal.ui.editor.ScriptAnnotationUtils.ha sCorrections(ScriptAnnotationUtils..java:39)
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
FUDForum. Page generated in 0.03832 seconds
