Home » Archived » XML Schema Definition (XSD) » xsd location and import problem
xsd location and import problem [message #37001] Mon, 02 February 2004 21:21 Go to next message
Originally posted by: cipher8000.yahoo.com
Hi Ed,
I recently upgraded to xsd 2.0, and started have few problems related to
schema location and imports:
Please find the attachment for foo.xsd. I have deployed my xsd files under
tomcat webapps ROOT/xsd folder and i refer them using this following URL:
http://localhost:7575/./xsd/foo.xsd
When i tried to validate this schema using xsd-standalone-test.bat, i get
the following:
c:>xsd-standalone-test.bat -validate http://localhost:7575/./xsd/foo.xsd
--> http://localhost:7575/./xsd/foo.xsd
Error: URI http://localhost:7575/./xsd/foo.xsd Line 1 Column 1
XSD: The element may not have duplicate name and target namespace
'http://www.foo.com/foo#foo'
'http://www.foo.com/foo#fooBoo'
Error: URI http://localhost:7575/./xsd/foo.xsd Line 17 Column 4
XSD: The type may not have duplicate name and target namespace
'http://www.foo.com/foo#FooType'
But if i use without "." (http://localhost:7575/xsd/foo.xsd) , then i don't
get validation error..
c:>xsd-standalone-test.bat -validate http://localhost:7575/xsd/foo.xsd
Please find the attachment for foo.xsd and boo.xsd. i deployed these files
under tomcat's webapps/ROOT/xsd directory.
thanks in advance for your help.
-muruga
  • Attachment: foo.xsd
    (Size: 0.86KB, Downloaded 202 times)
  • Attachment: boo.xsd
    (Size: 0.87KB, Downloaded 203 times)
Re: xsd location and import problem [message #37180 is a reply to message #37001] Thu, 12 February 2004 09:29 Go to previous message
Muruga,
I'm not sure anything has changed in this regard. The URIConverter's normalize
method never has done "." or ".." removal so if you initial starting URI may be
of that form, it's best to make sure it's canonical before passing it to the
resource set or you will end up loading the same resource using slightly
different URIs.
Muruga Chinnananchi wrote:
> Hi Ed,
> the following:
> -muruga
> foo.xsd Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
> boo.xsd Type: unspecified type (application/octet-stream)
Re: xsd location and import problem [message #583431 is a reply to message #37001] Thu, 12 February 2004 09:29 Go to previous message
Muruga,
different URIs.
> Hi Ed,
> the following:
> -muruga
Previous Topic:How to provide a different schema content
Next Topic:Unresolved element when validate using DOM format
Current Time: Wed Jul 16 09:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.08380 seconds
