Home » Language IDEs » ServerTools (WTP) » obtaining OperationType from WSDL model ?
obtaining OperationType from WSDL model ? [message #36450] Tue, 03 August 2004 12:02 Go to next message
Originally posted by: hoe.zurich.ibm.com
When I parse a WSDL document using code in plugin com.ibm.etools.wsdl
the resulting WSDLResourceImpl looks fine, except that
Operation.getStyle returns null instead one of the 4 valid
OperationTypes. Is this a bug, or how can one distinguish between WSDL
1.1 transmission primitives (esp. request-response and solicit-response)
instead?
Christian
Re: obtaining OperationType from WSDL model ? [message #36476 is a reply to message #36450] Tue, 03 August 2004 15:27 Go to previous messageGo to next message
> instead?
> Christian
It would be because the Operation does not have the style attribute and it
is an intended behavior. The method getStyle() returns the value of the
style attribute if it exists.
In your case, you will have to deduce the style yourself based on the
spec. when the style is not explicitly specified. e.g. by examining the
existance of Input and/or Output as well as their relative order.
Re: obtaining OperationType from WSDL model ? [message #36705 is a reply to message #36476] Wed, 04 August 2004 03:13 Go to previous messageGo to next message
Actually Christian, this is a bug in our model. Kihup, we should be the
ones deducing the style here ... we simply need to consider the presense
and order of the <input> and <output> elements. Christian, please open a
defect for this problem.
> > instead?
> > Thanks,
> > Christian
Re: obtaining OperationType from WSDL model ? [message #36773 is a reply to message #36705] Wed, 04 August 2004 03:42 Go to previous message
--------------070809000805060806030808
Content-Type: text/plain; charset=us-ascii; format=flowed
Craig,
Thanks & yes, I'll see if I can open a defect. I'm appending my current
workaround method (it's along the very line you're suggesting), which
should perhaps be refactored into OperationImpl.getStyle.
Kihup,
I think the style attribute is different (related to bindings, not
transmission primitives. Terminology overlaps here.
Christian
name="getStylt_patch.txt"
Content-Disposition: inline;
filename="getStylt_patch.txt"
public static OperationType getStyle(Operation operation) {
OperationType style = operation.getStyle();
if (style != null)
return style;
if (!(operation instanceof OperationImpl))
throw new AssertionError();
OperationImpl operationImpl = (OperationImpl)operation;
Element element = operationImpl.getElement();
NodeList childNodes = element.getChildNodes();
boolean passedInput = false, passedOutput = false;
for (int i = 0; i < childNodes.getLength(); i++) {
Node childNode = childNodes.item(i);
if (!(childNode instanceof Element) ||
!WSDLConstants.WSDL_NAMESPACE_URI.equals(childNode.getNamesp aceURI()))
continue;
String localName = childNode.getLocalName();
if ("input".equals(localName))
if (passedOutput)
style = OperationType.SOLICIT_RESPONSE;
else
passedInput = true;
else if ("output".equals(localName))
if (passedInput)
style = OperationType.REQUEST_RESPONSE;
else
if (style == null)
if (passedInput)
style = OperationType.ONE_WAY;
else if (passedOutput)
style = OperationType.NOTIFICATION;
else
operation.setStyle(style);
return style;
--------------070809000805060806030808--
Previous Topic:Problem with blanks in the Tomcat path
Next Topic:Be sure to check out J2EE Navigator View and Snippets View
Current Time: Mon Jul 21 21:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
