Multiple views unlinked across perspectives [message #3166] |
Tue, 13 May 2008 23:24  |
Hi all,
I've got two perspectives and there is a view (with a table) that I need
two instances of.
Consider this:
The view in perspective 1(View A) implements ISelectionListener, and loads
data from 'customer.id' provided by the ISelectionProvider (ie the
TableViewer) in another view in perspective 1 (View B).
I now want to add another instance of view A in perspective 2, and have it
updated by a customer.id provided by a different view (View C). I don't
want view A in perspective 1 to update.
Does that make sense?
Any ideas?
Re: Multiple views unlinked across perspectives [message #5976 is a reply to message #3166] |
Thu, 12 June 2008 01:22  |
Originally posted by: annamalai.ancitconsulting.com
Now not really sure ... but looks like you wanna open two instances of the
same view ... if that is the case you need to use primaryID, secondaryID
funda in showView method found in your activePage of the workbenchWindow.
"Glenn Gilbert" <glenn.gilbert@contact-energy.co.nz> wrote in message
news:82f12ab022f483cd6dcf712b0d08c640$1@www.eclipse.org...
> Hi all,
> two instances of.
> Consider this: The view in perspective 1(View A) implements
> ISelectionListener, and loads data from 'customer.id' provided by the
> ISelectionProvider (ie the TableViewer) in another view in perspective 1
> (View B).
> Does that make sense? Any ideas?
> Thanks
Re: Multiple views unlinked across perspectives [message #568797 is a reply to message #3166] |
> Hi all,
> two instances of.
> (View B).
> Thanks
FUDForum. Page generated in 0.05015 seconds
