Debugger needed to run a script? [message #36266] |
Tue, 17 July 2007 13:38 |
Originally posted by: dserodio.gmail.com
When I choose Run As... > PHP Script, Eclipse complains about the
debugger not being correctly configured in php.ini
Do I really need a debugger in order to run (as opposed to debug) a
simple PHP script?
Daniel Serodio
Re: Debugger needed to run a script? [message #36299 is a reply to message #36266] |
Tue, 17 July 2007 13:41 |
> simple PHP script?
> Daniel Serodio
You'll need a PHP executable. One that should work comes with the
installation of the Zend debugger plugin (get it at zend.com/pdt) . With
this you can debug PHP scripts locally.
If you then also want to debug on a remote server, you'll need an
additional dll / .so file in the server directories, as well as setting
it up.
Re: Debugger needed to run a script? [message #36332 is a reply to message #36299] |
Tue, 17 July 2007 13:50 |
>> simple PHP script?
>> Thanks,
>> Daniel Serodio
Thanks for your reply.
I already have a PHP executable (installed by XAMPP), and I've created
an entry in "PHP Executables" Eclipse preferences pointing to this
directory (C:\xampp\php).
> it up.
Re: Debugger needed to run a script? [message #36621 is a reply to message #36332] |
Wed, 18 July 2007 12:29 |
Originally posted by: Patrick.Schulz.brand-implementation-group.de
I think it goes into more detailed questions, (also that it iterests me
and I'm new in PDT).
Which executeable will be used when I'm going to run or debug a script,
not a web page?
What parameters are passed?
Is it needed to have / use different php.inis for that (like php-cli.ini)?
Any help is highly appreciated.
Regrds,
Patrick
Re: Debugger needed to run a script? [message #36655 is a reply to message #36621] |
Wed, 18 July 2007 13:20 |
> not a web page?
I think I can answer this one.
It's the php.exe under the directory selected in Window > Preferences >
PHP > PHP Executables
The only parameter passed (according to Process Explorer) is "-c
/full/path/to/script.php"
HTH,
Daniel Serodio
FUDForum. Page generated in 0.04053 seconds
