| Table styles help needed [message #340218] | Mon, 28 January 2008 18:14  |  |
| Eclipse User  |  |  |  |  | Hi, I need help with the following (I am using BIRT 2.1):
 - How to have "grid" type tables i.e. by default, if we have tables in our
 report, they dont have the "grid lines" on the columns and rows. Eg the
 table in Microsoft Word. I tried defining the style for the column with
 the borders but it doesnt work. My table has a border though
 - How to specify the margins/padding between the columns. I have two
 columns (column A is right aligned and co B is left aligned. As a result,
 these two columns appear close together. I want to put some space between
 them
 Thanks a lot!
| Re: Table styles help needed [message #345634 is a reply to message #340218] | Tue, 29 January 2008 04:01  |  |
| Eclipse User  |  |  |  |  | The first problem is caused by wrong target element selection. You should select Cell element rather than Data element, which can be easily done
 through the outline view. In the same way, you can set the margin and
 padding style in Box item of the style editor.
| Re: Table styles help needed [message #349774 is a reply to message #340218] | Tue, 29 January 2008 04:01  |  |
| Re: Table styles help needed [message #349849 is a reply to message #340218] | Tue, 29 January 2008 04:01  |  |
FUDForum. Page generated in 0.03003 seconds
