Compatibility between 2.2.1 and 2.3 [message #339916] |
Mon, 28 January 2008 12:34  |
I'm using now birt 2.3 m4, but I have some reports with crosstabs at
2.2.1, when I open this, Birt shows a message about compatibility
problems on some components (crosstab). When I run the report, this
throws exceptions about CubeQueryDefinition.
In the other hand, I would like to use the web viewer servlet for
display the reports with 2.3 runtime, but, what would happens with
reports with crosstabs at 2.2.1 version?.
Hans.
Re: Compatibility between 2.2.1 and 2.3 [message #345251 is a reply to message #339916] |
Mon, 28 January 2008 20:29  |
Hi Hans
Crosstab has some changes in 2.3.0, So please check is there any unused
bindings in your crosstab? If has, please remove them. Also check the
datetime type dimension(Year-Quarter-Month...Levels) in Cube and Crosstab.
The type of the levels should be Integer. In 2.2.0, they are not Integer
type. If you like, please attached your report, I'd like to help you to
check the issue.
Tianli
Re: Compatibility between 2.2.1 and 2.3 [message #349315 is a reply to message #339916] |
Hi Hans
check the issue.
Tianli
Re: Compatibility between 2.2.1 and 2.3 [message #349391 is a reply to message #339916] |
Hi Hans
check the issue.
Tianli
FUDForum. Page generated in 0.03390 seconds
