Re: Eclipse Taking Long To Install [message #1858383 is a reply to message #1858377] |
Fri, 31 March 2023 11:39 |
Ed Merks Messages: 33142 Registered: July 2009 |
The installer uses the following approach (which is different from p2's default, which blindly uses the first 4 listed mirrors). It sorts all the artifacts from smallest to largest, then partitions the list to move largest to the middle and the medium sized ones toward the end. Then it uses all the mirrors for the smallest artifacts first, measuring how fast each one is, and because they are small, getting that information relatively quickly so as to avoid using slow mirrors for large artifacts. I.e., it will use mirrors according to which ones were measured to be the fastest. I know it's happen to me more than once that one slow mirror for one small artifact uses more time than all the other downloads combined. So there isn't a perfect automatic solution. But I also don't plan to surface a list of mirrors for the users to choose. Each site potentially has a different set of mirrors and the user isn't likely to know which is fast just by looking the names, and that speed is likely to vary over time. But it is open source, so if you want to work on contributing something like that, you could...
Ed Merks
FUDForum. Page generated in 0.08349 seconds
