Sirius web problems with loading workspace Image [message #1852797] |
Sat, 04 June 2022 09:20 |
AMir Taghizadegan Messages: 32 Registered: May 2022 |
Member |
Hi everyone,
I have currently the following problem: Sirius web does not allow me to take a workspace Image for a newly created Node (in odesign file). If I do so the application fails to start with the following exception (full exception as screenshot):
java.util.MissingResourceException: The image resource 'full/obj16/Data' could not be located
at org.eclipse.emf.common.util.DelegatingResourceLocator.delegatedGetImage(DelegatingResourceLocator.java:393) ~[org.eclipse.emf.common_2.24.0.v20220123-0838.jar:na]
I can not even take a square for example, as a style for the node. Only a "Dot" works.
FUDForum. Page generated in 0.02866 seconds
