Home » Archived » BIRT » Wrong results in crosstab
Wrong results in crosstab [message #338785] Mon, 28 January 2008 08:43 Go to next message
Hi people,
I have a crosstab that shows some summarized fields, (A, B, C), when I
preview the results (at preview's tab), all goes fine, but viewing the
results in xls or web viewer, it results in strange data. The C field
shows strange numbers, very very big numbers. I have tried with a new
report file, but happens the same problem.
Any ideas?
Hans.
Re: Wrong results in crosstab [message #343739 is a reply to message #338785] Mon, 28 January 2008 08:51 Go to previous messageGo to next message
I forgot to add that I have two crosstabs. The problem happens sometimes
in first crosstab and other times it happens in the second crosstab
Hans escribió:
> Hi people,
> I preview the results (at preview's tab), all goes fine, but viewing the
> Any ideas?
> Hans.
Re: Wrong results in crosstab [message #343740 is a reply to message #338785] Mon, 28 January 2008 09:00 Go to previous messageGo to next message
Originally posted by: tigeleo.yahoo.com
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
May be you display rowid or time in milliseconds
Re: Wrong results in crosstab [message #355483 is a reply to message #343740] Mon, 28 January 2008 09:19 Go to previous message
Nope, and after a many crazy things, I can fix the problem. The solution
was to change all the report parameters to String. I've never had this
problem with crosstabs, indeed, I've worked with a template with the
same report parameters and same crosstabs, it's the first time that I
see this strange behaviour. Could be a bug?
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> when I preview the results (at preview's tab), all goes fine, but
>> viewing the results in xls or web viewer, it results in strange data.
>> The C field shows strange numbers, very very big numbers. I have tried
>> with a new report file, but happens the same problem.
>> Any ideas?
>> Thanks,
>> Hans.
Previous Topic:Wrong results in crosstab
Next Topic:Wrong results in crosstab
Current Time: Thu Oct 09 02:01:21 EDT 2025
Powered by FUDForum. Page generated in 0.07589 seconds
